Is there a way to store/restore current lighting status?
I'd love to be able to press a KeyLinc button that would turn all lights on but if I pressed it again instead of then turning all lights off it would restore the lights to the levels they were at before.
Is there anyway to do this using the ISY?
Rick
Sorry, no. Insteon devices do not remember where they were before the last On command. If all the devices should be restored to some Scene level the On/Off commands from the KeypadLinc button can trigger a Program that issues different Scene commands for the On and Off commands. The On command could run a Program Then clause which turns all the devices On and the Off command could run the Program Else clause and issue a Scene On for a different Scene that set the devices to some predetermined state. This would not take into account any devices that had been turned On/Off or dimmed/brighten manually.
