How to create addressable IR commands
In an effort to simplify things for other people in my house, and try to save buttons on my remote, I've created addressable commands ie: Channel up = ON, Channel down = OFF, Volume up = FADE UP, and Volume down = FADE DOWN, (or close variations of those commands) for any selected device. I did this by assigning number buttons to a device ie: 1=front door, 2=rear soffit etc. etc. The numbered IR commands don't execute an insteon function, they merely run a program for a selected period of time, I chose 7 seconds, which then becomes false, see following example
       IR '1' is Pressed
       Wait  7 seconds
       Run program 'IR address Front Door' (Else Path)
then the programs that actually execute the commands fade up, fade down, on or off
       IR 'Volume +' is Held
   And IR 'Volume +' is not Released
       Set 'Front Door' Fade Up
       Set 'Front Door' Fade Stop
are in conditional folders
Folder Conditions for 'IR Front Door'
Add conditions to limit when programs in this folder are allowed to run.
       Program 'IR address Front Door' is True
I also like this for two reasons
1) because it's similiar to X-10 remote functions which I've become used to
and 2) because it saves buttons on the remote (w/o addressing 6 devices times 4 separate commands = 24 buttons, vs. addressing where 6 devices + 4 commands = only 10 buttons
Thanks for sharing. I'll probably have time tomorrow, if all the anticipated precipitation occurs, to give this a shot.
Rand
Excellent, Zellerman. It occurs to me that this idea may also be useful with other types of controls such as X-10 remotes, or Insteon controllers when the next release with FadeUp/Down/Stop is out!
