Variables and Power Loss Behavior
What happens to variable values when a power loss occurs? It appears as if the variables reset to their initial value. Is this the case? If so, is there a way to persist them across a power loss?
I thought I read about this a while ago, and now I can't find it anywhere.
Your observations are correct. Set the variable Init value when the variable value is changed for those variables whose value should persist over a reboot.
Excellent. I didn't know you could do that, but I didn't look either. It is just like some of my programs I set to run at startup when I set them to enabled. Thanks a ton!
