request for ideas for a motion program
morreale
I have a 2420M Motion Sensor v.34 that Controls a SwitchLinc Relay v.3A that controls the 4 Florescent Fixtures in my garage.
Currently the 2420M is setup to turn the lights on when it detects motion. I do not have it turning the lights off after. All jumpers are off except #5 for ISY control.
I would like to write a program that will monitor motion and the switch to determine when to turn the fixtures off. is that even possible?
situation 1: I get home and open the garage doors and the motions sensor will detect movement and turn the lights on. once there is no more movement present (15 minutes?) turn off the lights
situation 2: i need to work in the garage and i manually turn on the lights. can ISY know that the lights were manually turned on and not turn off the lights even if there isnt movement?
what variables are there to be used with the motion sensor?
thanks!!!
You should be able to put the ms into occupancy mode (I don't remember the exact term used in the options menu) which will send an On command everytime it senses motion.
Then a standard program such as:
Program: Lite Auto Off
 Status 'Motion Sensor' is Off
 and Status Switchlinc is On
 and Program 'Manual Lite On' is False
Wait 15 minutes
Set Switchlinc Off
Nothing
If the light is on and the ms sends an On signal the wait will start over. The light will turn off 15 minutes after the last On signal, unless the next program is true.
Program Manual Lite On
 Control 'Switchlinc is switched On
and Control 'Switchlinc is not switched Off
When you manually turn the light on, you will have to remember to manually turn it off. Or another program with a longer wait time could be used to automatically turn it off.
Tim
thanks for the quick reply. i went ahead and added those two programs to begin playing with things to see how it works...
my auto off program doesn't seem to work because the motion sensor seems to remain in the 'on' state
Status 'Garage Interior / Motion-Sensor' is Off
And Status 'Garage Interior / Garage Interior Lights' is On
And Program 'Lights Manual On' is False
Wait 15 minutes
Set 'Garage Interior / Garage Interior Lights' Off
Control 'Garage Interior / Garage Interior Lights' is switched On
And Control 'Garage Interior / Garage Interior Lights' is not switched Off
The Motion Senser Status will never be Off if the Motion Sensor is sending only On commands.
hmm interesting. so what would be the point of the "then" portion of the program if the motion needs to be set to send the 'off' command and i can configure that for 15 minutes?
Wait 15 minutes
I am so sorry. Thats what happens when I try to post in a hurry....
This should work
Control 'Garage Interior / Motion-Sensor' is switched On
Wait 15 minutes
I got most of this from the wiki I think... It requires 4 programs, but will do everything you are looking to do
First is the program to turn the lights on once motion is detected. It uses the control line from the MS so that you can turn the lights off via the switch even if the status of the MS is On.
       Control 'Garage / Garage MS' is switched On
   And Status  'Garage / Garage Lights' is not On
   And Program 'Garage MS Timer Enable' is True
       Set 'Garage / Garage Lights' On
Second is the timer program that shuts off the light once motion ceases to be detected. I have it set to beep 4 times 1 minute before it shuts off as a warning. The timer program will be disabled if 'Garage MS Timer Enable' program is false. Which happens if you turn the switch on manually, thus allowing you to work without fear of the lights going out on you while you're still in the room. You just have to remember to turn them off when you're done...
       Status  'Garage / Garage MS' is Off
   And Status  'Garage / Garage Lights' is On
       Wait  3 minutes and 54 seconds
       Set 'Garage / Garage Lights' 1 (Beep Duration)
       Wait  2 seconds
       Wait  2 seconds
       Wait  2 seconds
       Wait  1 minute
       Set 'Garage / Garage Lights' Off
Third is the 'Garage MS Timer Enable' program. It basically allows the MS to be overridden. It will disable both the On and Timer programs if false.
       Set Program 'Garage MS Timer Enable' To Run At Startup
       Set Program 'Garage MS Timer Enable' To Not Run At Startup
Fourth is the program the sets 'Garage MS Timer Enable' program to true or false. If you have a dimmer switch, you could use Fast On as well, but as these are florescent, I'm not using a dimmer.
       Control 'Garage / Garage Lights' is switched On
   And Control 'Garage / Garage Lights' is not switched Off
       Run Program 'Garage MS Timer Enable' (Else Path)
       Run Program 'Garage MS Timer Enable' (Then Path)
Another program I like is just turning the lights on whenever I open the overhead doors. The ones on the opener aren't very bright and I like the added light when I pull in. The Timer program will also take care of these as well, so just park and go inside, they'll go off 5 minutes later. And again, using the control line allows you to turn off the lights if you want to leave the door open and have the lights off.
            Control  'Garage / Garage Door Sensor-Big' is switched Off
         Or Control  'Garage / Garage Door Sensor-Small' is switched Off
   And (
            Status  'Garage / Garage Lights' is Off
sweet guys...thanks for all the info. i am going to play with this and try to figure out this stuff.
i was running homeseer for years and am just now trying to get into programming using the isy.
i see now where my mistake is...i have the motion sensor in a scene with the switchlinc. i have now removed it and set the motion sensor to also send 'off' commands and i will let isy handle which devices to control.
starting to make sense :P
Cool. I did not know you can create audible warnings from Insteon switches. I will want to try this.
      37.7k
      377k
