Notification on Status Change
captain118
An ISY Program is necessary to accomplish that.
If Status xxxx is On
Or Status xxxx is Off
will trigger an ISY Program when the Status changes. The Program issues the Notify.
The "If Status" requires a change in the status value to trigger the Program. The Then or Else clause will run depending on whether the If evaluates to True or False.
Not sure of the function you are referring to. The ISY is event driven. It does not check status of anything every few seconds.
In your program you can have a schedule. Your schedule can have a duration.
I was trying to set my living room lamp for
if its during the day:
Schedule From 8am
For 10 hours
And Motion Sensor is off (no movement I think)
then Set Light Of
Else Set Light On
I was curious as to how the schedule worked. Is it a schedule for when the program is enabled?
Thanks for the additional information. The Program is triggered once at 8 AM, once 10 hours later at 6 PM, and between 8 AM and 6 PM once for each change in motion sensor status (using If Status) or once for each Insteon command received that matches the command code using If Control. Always event driven either from a time event or a device event in this example. There are other events such as a change in value of a State variable for example that can trigger Programs.
When the Program is triggered either the Then clause or the Else clause will run depending on how the If evaluates at the time the Program is triggered. When the If is True the Then clause runs, when the If is False the Else clause runs.
      38k
      379.4k
