Insteon Motion Sensor issue??
Trying to add a Insteon Motion Sensor (2420M) as a new device in the ISY-99i and it will not take it. It does not show up anywhere! I have tried over and over with no luck. Any suggestions? Do you add a Motion Sensor differently than other devices?
How is the Motion Sensor being added?
New INSTEON Device must be used and the Device Type pulldown must select Motion Sensor. Also the Motion Sensor must be put into linking mode using the Motion Sensor Set button.
However, if this is a new Motion Sensor purchased in the last few weeks you will need to wait for the 3.2.0 Beta which has a tentative date of 3/16/2012. The newest Motion Sensors are I2CS devices which require 3.2.0.
EDIT: the UDI Wiki has information on devices that are processed differently. RF devices tend to be a little different than wired devices.
http://www.universal-devices.com/mwiki/ ... de#Devices
