Venstar INSTEON Integrated Remote Control Thermostat 1-Day
I just installed a new Venstar thermostat and linked it in ISY.
It created 4 nodes : Cool Control, Fan Control, Heat Control and Main.
Everything works fines - from ISY or directly from the Thermostat - everthing is in sync - current state, setpoint, fan state and heat/cool state.
The only thing is that the Cool Control and Fan Control nodes don't show any state (no ON or OFF - it's just blank).
The thermostat is currently in Heat mode. Shouldn't the Cool Control node show OFF ? And when the heat/cool state is ON shouldn't the Fan Control show ON ? The Heat Control node correctly shows ON or OFF according to the heat/cool state in the Main node.
Any ideas ?
The Cool and Fan nodes will populate when the states for those change. If you cycle your fan (only) on/off, you'll see the correct status appear. Same with the cooling cycle. Hope this helps.
