Simple program problem
$GarageDoorSensor is 1
And From Sunset + 15 minutes
To Sunrise (next day)
Set 'Garage Exterior Light' On
Wait 1 minute
Set 'Garage Exterior Light' Off
The 'Garage Exterior Light' turns on properly when $GarageDoorSensor variable is set to 1 but does not turn off after 1 minute.
Any idea why ?
The State variable is changing value before the Wait 1 minute completes. This causes the If to be reevaluated as False driving the Else clause so statements after the Wait are not executed.
Yes - the state variable does change back to 0 before the 1 minute is up.
I would have thought that the Wait 1 Minute would prevent the program from reevaluating the IF.
How would I go about getting the desired behaviour ?
Any time a clause has a Wait or Repeat statement the If can be reevaluated. The UDI Wiki has an excellent explanation of how Repeat and Wait statements can affect execution of statements after the wait or Repeat.
One solution is to change the State variable in the Then clause
Wait 1 minute
$GarageDoorSensor is 0
Another solution is to move the Then logic to a second Program that has no If section. The current Program calls the second Program to perform the logic. The first Program cannot be reevaluated because there is no Wait. Even if it is reevaluated to False it does not affect the second Program.
