Programs
Last question of the night....I was trying to do a simple program to turn off my outside lights at a certain time.
I started a new program
I used the schedule feature to set the time and added it to the code
I then added AND Device A is on
or Device B is ON
Set Device A Off
and
Set Device B Off
When the program kicked off my lights started turning on and off and on and off like it was stuck in a loop. I trices ed deleting the programs (that didn't do it) and I tried to delete the devices (that has now caused all of my devices statuses to be blank and when I try to do anything I get Discovering Nodes, Retry.......
Suggestions? Please (before I snap and quit) Thanks.
-Edit - Need help quick. My F'ing lights are just turning on and off and I can't get them to stop
Mark the Programs Disabled to stop the execution.
There are a few problems in the Program you described. Suggest the Program be posted so the exact situation can be evaluated. The If statement needs parens to get the order of precedence correct. The Program probably changing the Status of a device used in the If. Assumptions until the actual Program can be seen.
I deleted them before I disabled them. They are no longer there but it is not stopping the lights.
Click on Save Changes. The Programs are not gone until the Delete is Saved
My neighbors thank you.
Any idea on what I did wrong with the programs?
I had 2 of them
Front Lights ON
Time is 8:30 PM
and status Front Porch is Off
or status Garage Lights is Off
Set Garage Lights On
Set Front Porch On
FronLights Off
Time is 9:50
and Status Garage Light is On
or Front Porch is On
Set Front Porch Off
Set Garage Off
End If
The order of precedence is not what you want. The first device Status is Anded with the Time, the second device status, the one that is Ored stands alone, not gated by time. There is a good write up on the order of precedence in the UDI Wiki if more information is needed.
Front Lights ON
Time is 8:30 PM
and
Set Front Porch On
FronLights Off
Time is 9:50
and
Set Front Porch Off
Set Garage Off
End If
It also looks like you can simplify the program. Based on what I'm seeing your simply trying to have the program turn on the outside lights when it gets dark and turn them back off again when it gets light. For example:
IF:
From 8:30 PM
To 9:00 AM (next day)
Set Front Porch On
Set Garage Lights Off
Set Front Porch Off
Nice, simple and condensed. I use a similar program for my outside lights. (except I use the time of sunset/sunrise)
Thanks for the suggestions. Makes much more sense and a lot cleaner.
IF:
From 8:30 PM
How do you code the above? I don't see the From and To options in the schedule section.
Under Schedule there is a multi selection field that displays "Time is" as the default, Click the down arrow and select From.
Got it worked out. Thanks for the help.....and patience with me.
