buttons on KPL chirp when pressed
On one of my KPLs, I hear a single chirp when any of the buttons are pressed (one chirp for each button press). The scenes associated with the buttons work. This has only been happening about a week, before that, no sound when button was pressed.
Is there a way to turn the chirps off or is there something wrong that I should be looking for?
From the KeypadLinc User Guide
Buttons can be set to Beep Mode so KeypadLinc will beep every time a button is used. (Default = Off)
If KeypadLinc in 6-Button Configuration
Simultaneously tap the B and C buttons
Keypad’s Beeper will toggle to on (if was off) or off (if it was on)
If KeypadLinc in 8-Button Configuration
Simultaneously tap the D and E buttons
Thanks for reply. I'll give that a try when I get home.
Learn something knew everyday.
