Insteon Thermostat
I have an ISSY 994 and a new Insteon Thermostate. Issy will not recognize the thermostat. Any suggestions?
I guess what I am looking for is:
Acknowledging that it is a new product, is it likely the Issy will eventually support it or,
If it is not communicating with it, then why? The Thermostat is RF and there are Dual Band dimmers within 6 feet each side of the thermostat.
The 2441TH is in the list of supported devices on 3.2.6.
What procedure is being used to add the 2441TH to the ISY? The actual steps.
Also check Help | About and verify Firmware and UI lines indicate 3.2.6.
Firmware is 3.2.6
UI is 3.1.17
How do I update UI?
To install the Thermostate, I went to Link Management, New Insteon Device. I entered the address and a name with auto detect. Nothing happens.
That UI indicates either the Java cache was not cleared or the wrong URL is being used to invoke the Admin Console.
I suggest following the procedure in the Wiki for adding a tstat.
If that is not successful run Tools | Diagnostics | Event Viewer with Level 3 selected. Repeat the Wiki sequence and post the event trace. It may provide some useful information.
