garage light program
hey guys does this look right?? i want to turn on the gargae light sfor 5 minutes and turn on the kitchen lights until manually turned off and notify me when garage is open thanks pete
From Sunset
To Sunrise (same day)
And Status 'garage door sensor' is On
Set Scene 'Garage Lights' On
Set Scene 'Kitchen Lights' On
Send Notification to 'text'
Wait 5 minutes
Set Scene 'Garage Lights' Off
Do you want the garage light to turn off five minutes after the door is opened, or after it is closed?
Using "status" for your garage door as a trigger, you run the risk that if the door is closed prior to the five-minute time period, the program will halt execution and the light will stay on. While unlikely, if you open the door less than five minutes prior to sunrise, you will have the same problem.
Try, instead, control:
From Sunset
And control 'garage door sensor' is turned On   <<< try "control" here, instead
Wait 5 minutes
 wait 5 minutes  <<< I would add these statements to account for the sunrise problem
 set scene "Garage Lights' off
well i tried it and the garage lights come on when door opens and shuts off when door closes ???? what did i do wrong should i use a light device instead of scene
If nothing else the If is wrong regardless of Status or Control ....
From Sunset
The To Sunrise must be (next day). The way it is written To time is before From time.
thank you sir.. works like a champ. here are the settings if anyone needs them
       From    Sunset  -  1 hour
       To      Sunrise (next day)
   And Control 'garage door sensor' is switched On
       Set Scene 'garage lights' On
       Wait  5 minutes
       Set Scene 'garage lights' Off
       Wait  5 minutes
