What exactly does the "Report Humidity" tstat option do?
I have a 2441V TA v.92. I note that there is an option to "Report Humidity". I did not find any documentation for this option when searching this forum or on the Wiki. (Perhaps I missed it?). What does the option do? If uncheck will a query still show the correct humidity? Does the option simply reduce the Insteon traffic for humidity variations?
  • 1 month later...
I've been playing around with sending alerts when certain thermostat events happen and have found that if you use the device variable CLIHUM with the "Report Humidity" option off, you don't get anything but if you turn the option on, then CLIHUM=${sys.node.14 92 10 1.CLIHUM} will show you the humidity in an alert email.
