jmed999 Posted July 7, 2012 Share Posted July 7, 2012 I just got the ISY994i up and running with a PLM. I bridged my 2 phases using an access point. I'm able to link the Lamplinc V2 (2456D3) but I then get a "cannot communicate with" error message. Any idea how to get the ISY to communicate with the 2456D3? Thanks in advance for the help! Link to comment Share on other sites More sharing options...
LeeG Posted July 7, 2012 Share Posted July 7, 2012 A 2456 is an ApplianceLinc which could require something plugged into the controlled outlet. What ISY firmware is being used? What does Help | About show for Firmware and UI lines? How was the Access Point confirmed to be on the opposite 120V leg and in RF range of the 2413S PLM? Link to comment Share on other sites More sharing options...
jmed999 Posted July 7, 2012 Author Share Posted July 7, 2012 I do have something plugged in so I don't think that is the issue. BTW, on the back it says it's a Lamplinc V2 2456D3 Link to comment Share on other sites More sharing options...
LeeG Posted July 7, 2012 Share Posted July 7, 2012 It sounds like a powerline communication problem. Plug the device into the same outlet as the PLM. Link to comment Share on other sites More sharing options...
jmed999 Posted July 7, 2012 Author Share Posted July 7, 2012 I'm running 3.2.6. How do I plug them both in the same outlet? Seems like they would be too big to do that. Link to comment Share on other sites More sharing options...
LeeG Posted July 7, 2012 Share Posted July 7, 2012 The 2456D3 has a passthru outlet. You can also plug both in the multiple outlet cord so long as it has NO surge/noise suppression. Link to comment Share on other sites More sharing options...
jmed999 Posted July 7, 2012 Author Share Posted July 7, 2012 That works! Not sure how to get the other one working. I'd hate to have to run all lamplincs with an access point piggy backed on it. Any suggestions? Thanks! Link to comment Share on other sites More sharing options...
Brian H Posted July 7, 2012 Share Posted July 7, 2012 The PLM is not plugged into a surge strip that has a noise suppressor in it? The PLM is not connected to the same outlet as the computer or an UPS is it? Many computer power supplies and UPS units have power line filters in them and can absorb the Insteon power line signals. Filtered surge strips can also. You may also want to selectively disconnect things like TVs Cell Phone Chargers and other electronic devices and see if they are making power line noise or absorbing the Insteon signals. If you find something a FilterLinc on the problem device may help. Link to comment Share on other sites More sharing options...
LeeG Posted July 7, 2012 Share Posted July 7, 2012 That was a test to confirm the device is functional. Now that it is confirmed to be a functional device, it not working elsewhere on the powerline indicates a powerline communications issue. All the things that Brian posted are potential issues for the beginner. Also exactly what steps did you follow and exactly what response was observerd to confirm active 120v coupling. It is important to be precise here. Link to comment Share on other sites More sharing options...
jmed999 Posted July 8, 2012 Author Share Posted July 8, 2012 Thanks for the replies guys! The PLM is not plugged into a power strip or anything like that. It's in an outlet all by itself. In the closet close by I do have a lot of TV components ie set top box, A/V receiver, google TV, Logitech RF remote receiver/blaster, Blue Ray player, router, modem and an antenna. To bridge the two phases I plugged the access point into a garage outlet and the PLM is in a bonus room upstairs (directly above the garage). I pressed the set button on the PLM 4 times until I heard it start beeping. I then went out to the garage and noticed the green light blinking on the access point. According to the instructions that bridged the phases. To confirm they were bridged I plugged the Lamplinc in an outlet close by then plugged the access point to the back of the lamplinc like you suggested and it is working. Now the problem is when I unplug the access point from the back of the lamplinc and into the first outlet when coupling the phases (the outlet close by), the lamplinc doesn't work well (I can adjust the ramp rate but cant turn on or off...it just sticks in the off position and I get an error). Also, another lamplinc I have inside the house isn't able to communicate with the ISY. Should I start unplugging elec items around the house one at a time to determine what is messing it up? What is the procedure for this? I want to make sure I do this perfectly. Thanks! Link to comment Share on other sites More sharing options...
LeeG Posted July 8, 2012 Share Posted July 8, 2012 I would temporarily plug the PLM into an extension cord and plug the extension cord into another circuit as far away from the other electronic equipment as possible. The electronic equipment should be isolated from the powe4rline with a FilterLinc even if they are not the source of this problem. If the extension cord test does not have a positive affect then start unplugging devices Link to comment Share on other sites More sharing options...
