MikeB Posted February 18, 2008 Posted February 18, 2008 Having a problem here trying to make a KPL v1.65 secondary the controller of a fairly large scene (7 responders). Can anyone confirm that they are using a KPL v1.65 secondary to control a scene containing at least 7 responders? If so, are you having any issues? In my setup, the devices respond reliably when the KPL secondary is pressed, but the button flashes - I believe indicating that a confirmation response wasn't received from one or more of the responders. I can eliminate the issue by dropping down to 4 responders, but it seems if I add a 5th+ responder the flashing starts. It doesn't seem to matter which 5th+ responder I add, so I don't think it's a problem with a particular device. I'm still troubleshooting here, but would like to hear some input. Thanks!
Guest Posted February 19, 2008 Posted February 19, 2008 Having a problem here trying to make a KPL v1.65 secondary the controller of a fairly large scene (7 responders). Can anyone confirm that they are using a KPL v1.65 secondary to control a scene containing at least 7 responders? If so, are you having any issues? In my setup, the devices respond reliably when the KPL secondary is pressed, but the button flashes I have one KPL 1.65. The F button controls only two devices and it flashes occasionally. Since the devices go on and off like expected, I don't consider this being and issue. G, and H buttons on this KPL control 7 devices, as well as each other, but I do it through the ISY. No flashing is seen on those buttons of course.
