My Very Complicated IR Light Control
Here is a sample program tree to control 1 light.
Each light consists of 15 programs.
START SEQUENCE
(Allows selection of multiple lights before sending command.)
       IR '[12]' is Pressed
       Wait  30 seconds
       Run Program 'IR Bed Left Start' (Else Path)
STOP SEQUENCE
            IR '[0]' is Released
         Or IR '[10]' is Released
         Or IR '[50]' is Pressed
   And Program 'IR Bed Left Start' is True
       Set 'Bedroom Left' Fade Stop
LIGHT ON
        And IR '[10]' is Pressed
    Or (
            IR '[12]' is Held
        And Program 'IR Bed Left Start' is False
        And Status  'Bedroom Left' is Off
       Set 'Bedroom Left' On
LIGHT OFF
        And IR '[0]' is Pressed
    Or (
            IR '[12]' is Held
        And Status  'Bedroom Left' is not Off
       Set 'Bedroom Left' Off
LIGHT BRIGHT
   And IR '[10]' is Held
       Set 'Bedroom Left' Fade Up
LIGHT DIM
   And IR '[0]' is Held
       Set 'Bedroom Left' Fade Down
LIGHT SET LEVEL (Repeat 8x (1-9))
   And IR '[1]' is Pressed
       Set 'Bedroom Left' 10%
I have discovered a fast way to "Batch" generate theese programs!
Export the tree, use an XML editor, use "Find & Replace", save as the new tree, then import.
Over 500 and counting!
:shock:
I hope this thing does not BLOW UP :!::!::!:
OK, I am done with IR stuff for now!
Now I am working on Voice Commands!!
:twisted:
