"Coming Home" Scene
I live in AZ where the summer heat is ridiculous.
We save a lot of energy by turning the thermostat down. However, I want to create a scene that is linked to a button on my home screen of my android (via MobiLinc) called, "Coming Home" which when set to "ON" will set the main house thermostat to COOL 81 deg F and HEAT 74 deg F (so that it works to heat in winter and cool in summer without having two separate buttons).
I can't seem to figure out how to create a scene like this? I've assigned keypad buttons in the house to a program which will set certain thermostat setpoints but never through a scene. Is this possible or should I stick with a program, which would be fired by a click of the widget?
I defined a Scene with the T2491T1E as Responder. The ISY displays Scene Input fields for Heat Setpoint, Cool Setpoint, Thermostat Mode, and Fan State.
What are you seeing with what thermostat?
Thanks for the reply...I didn't realize I could just drag each thermostat into the scene to set the parameters which is what I ended up doing and it works fine.
