Keypadlinc used as program trigger
I'm having difficulty setting up a keypadlinc button to act as a trigger for a program. The ISY-99 apparently does not detect the ON or OFF from a keypad button used as a controller. Any suggestions?
It could be phase coupling problem where the KeypadLinc is on the opposite 120V leg. It could be a link record problem. A right click on the KPL primary node, selecting Restore Device will rebuild the KPL link database.
Is this the only device that does not show a state change in the Admin Console when a button/paddle is pressed?
What level ISY firmware is being used?
Restoring Device resolved the issue.
-Thanks :D
