Disable Load Sensing on Plug In Modules
upstatemike
I don't know if the Insteon protocol supports it but it would be nice to be able to enable and disble the local control (load sensing) on plug in modules. Not only would it be nice to set this from the ISY admin screen but it would also be helpful to be able to confirm the current setting using the device query option.
I am also curious if you set this manually, will the setting be correct after a device restore? Or do you have to manually reset this each time you restore the device? Do I need to set it manually then delete and re-add the module to make sure the setting is reflected correctly in the ISY database for future restores?
