Putting filter between KPL8 and dirty load??
blueman2
I have a load controlled by a KPL8 that I suspect is causing some noise issues. Would a device like this be appropriate to install between the dirty load and the KPL8?
http://www.smarthome.com/4835/Leviton-6 ... ock/p.aspx
I understand that filters are usually used to block dirty loads from the rest of the house, but I am looking to block a load actually connected to an Insteon dimmer.
As long as the load is less than 5 amps and the filter is on the load side or even in the loads electrical box. It should work fine.
I know X10 users do it all the time and I think I have seen Insteon users also using them.
I have two installed just as you describe. Keep the filter on the load connection (red) and not the supply (black) and I expect you will be fine!
I had to use one of these in my undercounter lights in the kitchen ..
They are a set of four fluorescent fixtures that would turn on with an Insteon signal but they would not turn off.
When I installed this filter then I could properly control the lights both on and off with Insteon signals.
:D
Thanks! yes, this is exactly my problem too. Load turns on, but then will not turn off consistently. Also, the ISY will read the "ON" command, but never the "OFF" command. I am guessing the load creates so much interference, the ISY cannot 'hear' the off command. It 'hears' the ON command because it gets that before the load kicks in.
I will give one of these a try!
Can turn On but not Off can be caused by the load being so noisy or a severe signal absorber. That when On the module can't be controlled.
So your theory sounds correct.
      37.1k
      371.5k
