Icom Lamp Dimmer: Can link and query, but not turn on or off
I have an older Icon lamp dimmer #2856D2 (v1.2) that I can add to my ISY-99ir pro, but I get "Cannot communicate with Try (4 B1 2D 1). Please check connections." The error clears when I query, but then always occurs again when any control is sent. This is with a lamp or with nothing plugged in. Other devices work on the same outlet. The log is empty, and when I select error log, I get "Request failed". I am using firmware 3.2.6. Any help would be appreciated.
Run Tools | Diagnostics | Event Viewer at Level 3. Issue the On or Off command and post the trace.
EDIT: include a Query in the trace after the On or Off command failure.
This is a query, ON, query.
Sun 10/07/2012 01:56:01 PM : [iNST-TX-I1  ] 02 62 04 B1 3D 0F 19 00
Sun 10/07/2012 01:56:01 PM : [iNST-ACK    ] 02 62 04.B1.3D 0F 19 00 06          LTSREQ (LIGHT)
Sun 10/07/2012 01:56:01 PM : [iNST-SRX    ] 02 50 04.B1.3D 1B.FC.37 27 00 00           (00)
Sun 10/07/2012 01:56:01 PM : [standard-Direct Ack][04.B1.3D-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 10/07/2012 01:56:01 PM : [   4 B1 3D 1]       ST   0
Sun 10/07/2012 01:56:01 PM : [   4 B1 3D 1]       OL 255
Sun 10/07/2012 01:56:01 PM : [   4 B1 3D 1]       RR  31
Sun 10/07/2012 01:56:05 PM : [iNST-TX-I1  ] 02 62 04 B1 3D 0F 11 FF
Sun 10/07/2012 01:56:05 PM : [iNST-ACK    ] 02 62 04.B1.3D 0F 11 FF 06          LTONRR (FF)
Sun 10/07/2012 01:56:06 PM : [iNST-SRX    ] 02 50 04.B1.3D 1B.FC.37 A7 11 FE    LTONRR (FE)
Sun 10/07/2012 01:56:06 PM : [standard-Direct Nack][04.B1.3D-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 10/07/2012 01:56:06 PM : [   4 B1 3D 1]      ERR   1
Sun 10/07/2012 01:56:11 PM : [iNST-TX-I1  ] 02 62 04 B1 3D 0F 19 00
Sun 10/07/2012 01:56:11 PM : [iNST-ACK    ] 02 62 04.B1.3D 0F 19 00 06          LTSREQ (LIGHT)
Sun 10/07/2012 01:56:12 PM : [iNST-SRX    ] 02 50 04.B1.3D 1B.FC.37 27 00 FF           (FF)
Sun 10/07/2012 01:56:12 PM : [standard-Direct Ack][04.B1.3D-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sun 10/07/2012 01:56:12 PM : [   4 B1 3D 1]      ERR   0
Sun 10/07/2012 01:56:12 PM : [   4 B1 3D 1]       ST 255
Sun 10/07/2012 01:56:12 PM : [   4 B1 3D 1]       OL 255
Sun 10/07/2012 01:56:12 PM : [   4 B1 3D 1]       RR  31
Thanks for the trace data. The ICON NAKed the On to 100% request. This is not a powerline communications problem. What type of load is plugged into the ICON, incandescent or other?
If not incandescent try a conventional bulb and make sure the device is switched On so the ICON can sense the load.
I tried it with no load, and with incandescents.
D'oh, when I plugged the lamps in, I had the switches off. Apparently the Icon needs a load? In any case, it works great now. Thanks again!
      37.2k
      372.5k
