Fanlinc Options
Can the fanlinc be controlled via the Venstar Thermostat 2491T1E? I would like to put one in my bedroom and control it via the Venstar stat or maybe the Insteon wireless thermostat 2441ZTH. Will it work with both of those?
I'd like it to change speeds at different temperatures. Also can the fanlinc reverse the fan direction based on temp...ie if it get cold reverse direction and change to low speed? The smarthome description didn't say anything about being about to change fan direction.
The current temperature is a value that can be checked just like the Bright level of a Dimmer. A set of ISY Programs could adjust the FanLinc Motor On Level for various ambient temperature ranges.
The FanLinc cannot reverse the Fan direction.
My normal ceiling fan remote can change the fan direction and I like that capability so I guess stick with that
