RL2 2444 last 2 buttons not working?
I have a Remote Linc 2 (2444) and it appears (to me at least) that the bottom 2 buttons don't work. I have set the device in 8 button non-toggle mode, and when i press any of the other 6 buttons (a-f) i can see in the event viewer a message like : [ 1C 20 BD 3] DON 0,but when i press g or h, nothing. The led on the device flashes green, however so I know I have actually pressed the button. Is this a device issue, or something else?
Sounds like the link database has been compromised. Put the RemoteLinc2 into linking mode with its Set button, right click the RL2 Primary node (button B), select Restore Device.
Actually, there should be no links, as I dd a factory reset and have not done any linking with it, but I will try this.
Doh! I figured it out. Turns out I must have linked it to the ISY in a mode where it ignored those buttons (4 scene?). When I looked at the ISY link table there were only links for the 6 buttons. So all I had to do was remove it from the ISY, the re-link it. Viola, it works now - all 8 buttons! Thanks for the clue on the link table, that's what mae me go look there.
