Cannot turn off LED on Fanlinc
barkster
I updated my firmware to 3.3.5 and linked my fanlinc to my system and went to set options and unchecked led backlight but my led's do not go off. I've tried checked and unchecked. the system is communicating with the fanlinc because I can turn it off and on.
Also, I had a remotelinc2 buttons linked to the fanlinc before I linked to isy99 and it was lost after I linked. What's the procedure to get the fanlinc linked to isy99, remotelinc2 and keypadlinc? Do I need to do all my programming in the isy99 and not manually link the buttons? I was a little confused on the linking process.
"Do I need to do all my programming in the isy99 and not manually link the buttons?"
Yes. Manual Set button links should not be done with the ISY. Define an ISY Scene, adding the appropriate RL2 and KPL buttons as Controllers and the FanLinc Light or Motor node as Responder
I'm running 3.3.6. I can turn the FanLinc LED Backlights On and Off on an I2CS FanLinc. Is yours an I2CS device? Could try right click, diagnostics | query Insteon Engine and then see if LED Backlight check box works.
Unchecked. The two LEDs actually turn On and Off on mine as I check and uncheck the LED Background check box. Run Tools | Diagnostics | Event Viewer at LEVEL 3. Are commands traced as the LED Background check box is checked and unchecked. Give it a few seconds between checking and unchecking the box for the command to be executed and a response received.
Post the event trace if the LEDs are not reacting
Ok I'll do that saturday, I bought a filterlinc to put on that battery backup that is on that circuit. I had it unplugged during the setup/testing so couldn't have affected it. I did notice though, with the storms last night and the power going off several times that when I woke up the leds were off. I'll test more on saturday. Thanks
      380k
