Looking for a better way (Random)
I currently have this program to light 2 lamps when someone enters the house...
Living Room Lamps
       From    Sunset
       To      Sunrise (next day)
   And (
            Elk Zone 'Front Door' is Violated
         Or Elk Zone 'Garage Entry Dr' is Violated
       Set Scene 'Living Room Lamps' Fast On
       Wait  5 minutes
       Set Scene 'Living Room Lamps' Fast Off
       Wait  5 minutes
I would also like to add a program to randomly turn those lamps on and off while we are away so I have this...
Random Lights
       From    Sunset
   And Program 'Living Room Lamps' is False
   And Elk Area 'The Home' 'Armed State' is Armed Away
       Set 'Insteon Bulb 1' On
       Wait  1 minute  (Random)
       Set 'Insteon Bulb 1' Off
       Set 'Insteon Bulb 2' On
       Set 'Insteon Bulb 2' Fast Off
       Run Program 'Random Lights' (Then Path)
Is there a better way to do this? The lamps aren't very random. They just turn on for 1 minute then the other one turns on for 1 minute.
Thoughts?
That "random" is not working?
Well, at 1 minute, what do you expect them to do? Turn on and off every minute or so like a light show?
Extend the time to like 15 minutes or 30 minutes. It might give you a more human touch.
So if I change it to 15 minutes and random it will just wait for 15 minutes right? What does selecting random do?
Thanks for the help!
According to the wiki, choosing a "random" wait will vary the time between zero and the specified time. I am unsure if it is multiples of seconds, minutes, or something else. Try it and see how it works with a longer period.
I ran this test Program with 5 Wait 1 minute (Random) statements. The actual Wait times were 26, 17, 0, 51, and 2 seconds. This was run on 3.3.9 (RC6). A Wait 1 minute Random seems to be working okay here.
Send X10 'A1/On (3)'
Wed 01/16/2013 10:14:43 PM : [X10] A1/On (3)
26 second wait
Wed 01/16/2013 10:15:09 PM : [X10] A1/On (3)
17 second wait
Wed 01/16/2013 10:15:26 PM : [X10] A1/On (3)
0 second wait
51 second wait
Wed 01/16/2013 10:16:17 PM : [X10] A1/On (3)
2 second wait
Wed 01/16/2013 10:16:19 PM : [X10] A1/On (3)
