Easiest way to turns lights off 10 minutes after turned on
Newbie here.
Between 1 am and 5 am, I need to turn on some lights when a motion sensor trips on, then turn the lights off 10 minutes later. Can I get this accomplished in 1 program?
Each time motion On is sent by the motion sensor the Scene is turned On and a 10 minute Wait established. If additional motion On messages are received before the Wait completes the 10 minute wait is reestablished so the Scene Responders remain On for 10 minutes past last motion On. The Scene is turned Off at 5 AM regardless.
Control 'Motion Sensor I2CS-Sensor' is switched On
And From 1:00:00AM
To 5:00:00AM (same day)
Set Scene 'SceneSwitchLincDimmers' On
Wait 10 minutes
Set Scene 'SceneSwitchLincDimmers' Off
In case it is not clear, also be sure that the motion sensor is not also part of the scene being controlled by the program.
