Lights coming on full instead of dimmed
I have a KPL key (6) that is a controller for a scene that includes turning on the load controlled by the same KPL's key (1). Unfortunately, the load lights come on full instead of at the 30% dimmed rate that is specified in the scene. All of the other lights in the scene come on as expected.
Any ideas on what I may not be doing?
There is a program that I don't think is involved in the problem...but I'll include it in case it is and I don't understand why... (The program just checks all of the loads in the scene and, if they are all on at any level, shows so by lighting up the KPL key - or turning it off whenever any one of the lights in the scene is turned off).
Status 'Loads / 1FL S6-1FL Hall Overheads' is not Off
And Status 'Loads / 2FL O1-Lamp' is not Off
And Status 'Loads / 2Fl S2-2FL Hall Overheads' is not Off
And Status 'Loads / BFJ-O1 Couch Lamp' is not Off
And Status 'Loads / Din O1-Curio' is not Off
And Status 'Loads / Din S1 Chandelier' is not Off
And Status 'Loads / Entry O1 Lamp' is not Off
And Status 'Loads / Fam O1 LLamp' is not Off
And Status 'Loads / Fam O3 RLamp' is not Off
And Status 'Loads / Fam S2 Overhead Center' is not Off
And Status 'Loads / Fam S3 Overhead Left' is not Off
And Status 'Loads / Fam S6KPL-1 Fam Overhead Righ' is not Off
And Status 'Loads / Fr Door KPL-1 Foyer Overheads' is not Off
And Status 'Loads / Fr Door S2 Front Porch' is not Off
And Status 'Loads / Kitchen-S1 Counter Lights' is not Off
And Status 'Loads / Liv-O1 Piano Halogen' is not Off
And Status 'Loads / Liv-O2 Fireplace Lamp' is not Off
And Status 'Loads / Liv-O6 Desk Lamp' is not Off
And Status 'Loads / Office S1 Halogen' is not Off
And Status 'Loads / 0FL S2N-0FL Hall Overheads' is not Off
And Status 'Loads / 0FL S4-Basement Skonces' is not Off
Set Scene 'KPL Indicator Lights / Fr Door KPL-6' On
Set Scene 'KPL Indicator Lights / Fr Door KPL-6' Off
It is the Scene definition that controls the On Level. Can you post the Scene definition when the KeypadLinc Controller button is selected (below the Scene name).
What ISY Firmware level is being used?
1) https://www.dropbox.com/s/h3c0xsak2chihco/ISY.GIF
2) v.3.3.8
Also, I didn't mention before, the lights come on dimmed if I turn the scene on from the ISY. Only when I press the KPL key do they come on full - and as I said before, it's only the load that is controlled by the KPL's first button that comes on full.
Click on the Red KPL button node name below the Scene name. Check the KPL load button On Level when the Red KPL button node name is selected. Every Controller has a unique set of Responder values. The posted image (thanks for that image) shows some of the Responder On Levels when the ISY PLM is the Controller (using the ISY Scene name). Need to check the Responder values for when the Red KPL button node name is the Controller (when the Red KPL button node name is pressed).
