Doorbell trigger
I'm using an I/O Linc and an ELK-930 to detect when someone presses the doorbell. I have a program that runs when the button is pressed. I would like to only run the program once if someone presses the button 3 or 4 times in a row. Then after 5 minutes or so it would reset and recognize the next time someone presses the button. The simple program that I have now runs every time the button is pushed, even if the button is pushed several times back-to-back. I couldn't think of a way to use variables to solve this issue. Any ideas? Thanks.
Hello,
Try this
Door Bell Switch is Switched On
and Integer Var1 is 0
Ring Bell
Set Integer Var1 = 1
Wait 5 minutes
Set Integer Var1 = 0
Tim
edit: The first time the door bell switch is pushed and the var1 is 0 the program will run and ring the bell once. But the second time within the waiting period the button is pushed the program will evaluate as Fasle. So try adding a Wait 5 minutes followed by Set Integer Var1 = 0 to the Else section. Then once the switch is pushed a second time and the program evaluates to False the timer will start again. 5 minutes after they stop pushing the button the var1 will be reset to 0 which will allow the program to run and ring the bell when the switch is pushed.
I use the Elk DB module with an IOLinc and IP camera with GPIO at my front door. When someone presses the doorbell. I turn on the light, close IOLinc relay which triggers the camera to send a picture to my phone. I don't have to get off the couch to see who it is. Usually it's a package delivery.
Thanks Tim, that worked perfectly. I guess I did not realise that you could have multiple instances of the same program running at the same time.
Thanks again,
Tom
Hi Tom,
Glad it worked out for you.
Actually its not multiple instances. Anytime there is a Wait in the action, either in the Then or the Else and something changes in the If the program will re-evaluate. In this case the only trigger is the bell button being pushed. The Integer variable will not cause a re-evaluation.
Anyway, glad it worked and thanks for posting back.
Tim
