sandymctyre Posted January 23, 2013 Posted January 23, 2013 Good day all, newbie to the forum, and to UDI / Insteon. I have an ISY994i running 3.2.6 and a 2487S V4.1. If I turn a scene off or on using the button on the KPL...the LED indicator turns on (or off) as the case may be. However, if I control as a scene through the ISY, the LED indicator never changes...so I cannot tell, looking at the KPL if a scene is off or on. Is there any way to have the indicator work, even if controlled through a scene? (ON when the scene is on...OFF when the scene is off?) Thanks, John
LeeG Posted January 23, 2013 Posted January 23, 2013 Add the KeypadLinc button as a Responder in the ISY Scene. Turning the Scene On/Off will cause the KeypadLinc button as a Responder to turn On/Off.
sandymctyre Posted January 24, 2013 Author Posted January 24, 2013 Add the KeypadLinc button as a Responder in the ISY Scene. Turning the Scene On/Off will cause the KeypadLinc button as a Responder to turn On/Off. Thanks LeeG for the prompt response. The KPL button is both a responder and controller in the scene already. Is there a different way to add it into the scene? Thanks, John
LeeG Posted January 24, 2013 Posted January 24, 2013 Once added to an ISY Scene as a Controller there is no need to add it as a Responder. The ISY assumes a Controller is also a Responder. Delete the Responder definition if it was also added to the Scene as a Responder. To confirm my understanding, an ISY Scene has a Secondary KeypadLinc button as a Controller of the Scene. When the Scene is turned On/Off either through the Admin Console or a Set Scene On/Off Program statement the Secondary KeypadLinc button LED does not turn On/Off in response to the Scene On/Off. That should work if as described above. Could be a link record did not get written to the KeypadLinc for some reason or there is a comm problem between the PLM location and that KeypadLinc location. Suggest running a Scene Test on that Scene and see if the results show success or failure for that specific KeypadLinc button. If it fails consistently do a Show Device Links Table for the KeypadLinc and click Compare when the display is complete. Does the Compare indicate the link records are correct? If the Scene Test works then there is some marginal comm between the PLM location and the KeypadLinc location.
