Stuck state?
I've got a scene "MBR-Master" that has stopped reporting it's state properly. It basically just looks like it's always on in MobiLinc.
When I do the "Scene Test" it tells me everything is fine, but when I refresh in MobiLinc I guess a bunch of errors telling me it can't open certain files. Here is the log:
Tue 01/29/2013 06:07:01 PM : [GRP-RX      ] 02 61 15 13 00 06
Tue 01/29/2013 06:07:02 PM : [iNST-SRX    ] 02 50 1A.E0.21 1E.80.B1 61 13 15    LTOFFRR(15)
Tue 01/29/2013 06:07:02 PM : [std-Cleanup Ack] 1A.E0.21-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Tue 01/29/2013 06:07:02 PM : [CLEAN-UP-RPT] 02 58 06
Tue 01/29/2013 06:07:02 PM : [iNST-SRX    ] 02 50 1E.F5.61 1E.80.B1 61 13 15    LTOFFRR(15)
Tue 01/29/2013 06:07:02 PM : [std-Cleanup Ack] 1E.F5.61-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
----- MBR-Master Test Results -----
[succeeded] MBR-FloorLamp (1A E0 21 1)
[succeeded] MBR-TableLamp (1E F5 61 1)
Tue 01/29/2013 06:07:16 PM : [FileOpen    ] Open failed for [/CONF/INTEGER.VAR] (r)
Tue 01/29/2013 06:07:16 PM : [FileOpen    ] Open failed for [/CONF/STATE.VAR] (r)
Tue 01/29/2013 06:07:17 PM : [FileOpen    ] Open failed for [/CONF/ELECMTR.CFG] (r)
Tue 01/29/2013 06:07:17 PM : [FileOpen    ] Open failed for [/CONF/ELEC.CFG] (r)
Tue 01/29/2013 06:07:18 PM : [FileOpen    ] Open failed for [/CONF/INTEGER.VAR] (r)
Tue 01/29/2013 06:07:18 PM : [FileOpen    ] Open failed for [/CONF/STATE.VAR] (r)
Tue 01/29/2013 06:07:18 PM : [FileOpen    ] Open failed for [/CONF/ELECMTR.CFG] (r)
Tue 01/29/2013 06:07:18 PM : [FileOpen    ] Open failed for [/CONF/ELEC.CFG] (r)
Tue 01/29/2013 06:07:24 PM : [FileOpen    ] Open failed for [/CONF/INTEGER.VAR] (r)
Tue 01/29/2013 06:07:24 PM : [FileOpen    ] Open failed for [/CONF/STATE.VAR] (r)
Tue 01/29/2013 06:07:24 PM : [FileOpen    ] Open failed for [/CONF/ELECMTR.CFG] (r)
Tue 01/29/2013 06:07:24 PM : [FileOpen    ] Open failed for [/CONF/ELEC.CFG] (r)
I've tried to download all in mobilinc, I've tried cycling the scene from the ISY, I've also disable all programs that pertain to the scene.... but no luck.
Any ideas?
The file errors do not mean anything. Two of them are the result of not having any variables defined.
Scenes do not have Status as far as Insteon is concerned. I don't use MobiLinc. Is it the devices in the Scene that do not show the correct status? The communication with some devices is poor (the Hops Left=0 previously mentioned) so Scene failures (not Scene Test) would be expected as Scene On/Off does not have the retry built into the Scene command other Insteon commands have.
No, the devices themselves report everything fine, but in the MobiLinc app, it still shows the status as "ON" even after refresh.
This is that when the MobiLinc client things are scene is ON and you click on it, it issues the OFF command and vice-verse. So without proper status (as it used to work yesterday, and does for all other scenes), you can't easily turns scenes on and off.
In MobiLinc the Scene is turned On and MobiLinc shows the Scene as On but when the Scene is turned Off in MobiLinc the Scene still shows On?
Yes. Regardless of how the scene is turned on or off, from MobiLinc or from the ISY admin console... MobiLinc always shows the scene as ON.
If you go into the expended options in MobiLinc for the scene, you can still click it ON, OFF, FAST ON and FAST OFF and everything works normally... just no scene status update.
The odd part is that with another instance of MobiLinc, which I assume has another database.... the same thing happens.
I will post it in the other forum though.
