Use of If From/For argument
I am new to the ISY world. I am trying to turn a light on at a given time and then turn it off again 2 hours latter. Here is my coding:
If From Sunset + 45 minutes
For 2 hours
Then set 'Family room lights' 55%
set 'Kitchen lights' 55%
Else no actions
Then lights come on, but have to be manualy turned off. What am I doing wrong?
The Program has no statements to turn the devices Off. The Then clause is invoked at the From Time because the If evaluates to True. The Program is triggered again at the +2 hours invoking the Else clause because the If is now False. The current time is outside the time range, albeit seconds outside the range, which is why the If is False driving the Else. The Else contains the statements to turn the devices Off.
For 2 hours
Else set 'Family room lights' Off
set 'Kitchen lights' Off
If I may make another observation, you may also benefit from a scene. If you were to create a scene (giving the name of you choice) that includes the family room and kitchen lights, as responders, with 55% on levels each, then your program could be even more simplified. It might even be more responsive.
if
time if from sunset + 45min
for 2 hours
then
set scene on
else
set scene off
One other observation, is do you want the lights to ALWAYS turn off 2 hours later, e.g. someone is in the kitchen cutting with a knife and the lights go OFF.
Might be a good idea to check for a control of the kitchen light in another program and stop this program from turning them off.
