HomeKit Support via HomeBridge - Siri Voice Control
rayzor
I have the same Error as RaginBallin:
i haven't had any trouble with hue or other plugins, but i can't get this one going:(
ateliers-Mac-mini:homebridge2 atelier$ /usr/local/lib/node_modules/homebridge/bin/homebridge
Loaded plugin: homebridge-isy-js
Registering platform 'homebridge-isy-js.isy-js'
Loaded config.json with 0 accessories and 1 platforms.
Loading 1 platforms...
[isy-js] Initializing isy-js platform...
Loading 0 accessories...
/usr/local/lib/node_modules/homebridge-isy-js/node_modules/isy-js/isy.js:404
        if (response instanceof Error || response.statusCode != 200) {
TypeError: Cannot read property 'statusCode' of null
    at Request.<anonymous> (/usr/local/lib/node_modules/homebridge-isy-js/node_modules/isy-js/isy.js:404:50)
    at emitTwo (events.js:87:13)
    at Request.emit (events.js:172:7)
    at Request.mixin._fireError (/usr/local/lib/node_modules/homebridge-isy-js/node_modules/restler/lib/restler.js:207:10)
    at ClientRequest.<anonymous> (/usr/local/lib/node_modules/homebridge-isy-js/node_modules/restler/lib/restler.js:246:14)
    at emitOne (events.js:77:13)
    at ClientRequest.emit (events.js:169:7)
    at Socket.socketOnData (_http_client.js:310:9)
    at Socket.emit (events.js:169:7)
here's my config:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "031-45-154"
    "description": "This is an example configuration file with all supported devices. You can use this as a template for creating your own configuration file containing devices you actually own.",
    "platforms": [
            "platform": "isy-js",
            "name": "isy-js",
            "host": "192.168.254.110",
            "port": "80",
            "username": "admin",
            "password": "passwordgoeshere"
    "accessories": [ ]
any help would be appreciated
Link to comment
  • 1 year later...
In reading through this topic, it looks like Homebridge allows you to present your Insteon / Wave ISY devices to HomeKit.
But what about home kit devices --> ISY ?  If i wanted to get a notification of a HomeKit light turning on for example, is that part of the functionality as well?
thanks,
Steve
Link to comment
  • 2 months later...
I'm hoping someone can help. I have successfully installed Homebridge on my iMac along with the ISY Helper plug-in. All of my devices are recognized and function correctly for a short while usualy 1-2 hours and then all a sudden, all of my devices show "no response" from within the iOS Home app. During this time I can confirm that Homebridge is still running and even stippling and restarting Homebridge has no effect. The only way to recover once this happens is to delete the home from the Home app, then delete the persist and cached folders from Homebridge and completely rebuild all of my devices. Then this scenario repeats...
Any ideas?
Chuck
Link to comment
  • 2 months later...
