AD2USB -> NSLU2 -> ISY-99
I am trying to get my Ademco Vista 20 panel successfully communicating with my ISY-99.
Based on research, it seems the best way to do that is to use an AD2USB device, connected to a hacked NSLU2 to create a "Network Device" that can communicate directly with the Ademco Panel.
So far, I have acquired an AD2USB, downloaded the ser2sock.c software, and hacked (uNSULng) the NSLU2.
I am having a great deal of difficulty on how to proceed.
I believe the next step is to cross-compile ser2sock.c on the NSLU2.
Has anyone successfully done this?
All help appreciated!
I've never used that device but I have been playing around with the NSLU integrated with the isy-99i. (I posted some threads in the Network Resources secton). Which software version did you use to hack your NSLU? I used the basic one - Unslung.
I've had to compile one program on my NSLU. I had to download the development package wich included the compilers. I looked quick, but I couldn't figure out what I loaded. Once you have that, you sould be able to compile that program.
Based on this article:
http://www.nslu2-linux.org/wiki/Applications/AlarmSlug It looks like the NSLU should recognize the USB adapter with the built in drivers?
I'll look so more for the compilers, and see if I can figure out what I used.
Thanks. The compilers is what I need help figuring out.
Once I get it running, I'll write up a how to for others.
Waht I did was load the package called optware-devel. On my Unslung version it's :
ipkg install optware-devel
It's a really large package. 150mb+ I think. Some additional informaiton here: http://www.nslu2-linux.org/wiki/HowTo/N ... ngPackages
That package includes a bunch of stuff. More than is probably necessary. Someplace it installs gcc the c compiler. I think that's what you will need. You should be able to move forward from there.
I loaded that package, but I still get command nit found errors for gcc and cc. Did you have to make any path changes?
I don't think I made any changes. When I was using it, it was to compile a module to be used with the LUA interpreter. ( a language I know very little about ). I used the MAKE and .config that came with it.
Did you reboot the NSLU after making that changes? Maybe some environment variable needs to be set?
David
I just logged into my NSLU, using puTTy in WINSCP. I logged in as ROOT. At the command line I type just GCC and I got "no input files". So it's finding GCCc fine.
Does your c program require something else? Is it downloadable someplace? I could try and compile it and see what errors I might get. If it compiles on mine, that it would be some kind of config issue at your end.
I did find a copy of ser2sock.c here: http://www.nutech.com/index.php?option= ... =4&id=1158
I was able to execute gcc ser2sock.c and it came back without any errors. (logged in as root).
I'm not exactly sure where the output goes, but I recieved no errors.
David
David
Any chance you can send me the resulting executable?
I was able to compile it. I had to move it into /opt/bin to make it execute. Then change the permissions 0755.
I couldn't upload it as it was - it doesn't have an extension.
Rename it to just ser2sock from ser2sock.zip. I copied it using WinSCP from the NSLU. I hope it goes back jsut as easily.
If you can't download it from here, I'll email. Let me know if that works.
ser2sock.zip
Here is the output I get when I run it:
Welcome to Unslung V2.3R63-uNSLUng-6.10-beta
---------- NOTE: THIS SYSTEM IS CURRENTLY UNSLUNG ----------
BusyBox v1.3.1 (2007-12-29 03:38:35 UTC) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# ser2sock
Usage: ser2sock -p -s
-h, -help display this help and exit
-p port socket port to listen on
-s serial device ex /dev/ttyUSB0
options
-i IP bind to a specific ip address default is ALL
-b baudrate set buad rate default to 9600
-d daemonize
-t send terminal init string
-g debug level 0-3
-c keep incoming connections when a serial device is disconnected
-w milliseconds delay between attempts to open a serial device (5000)
Error missing serial device name exiting
Thanks for the file. I downloaded it ans was able to successfully run it with the same result.
Now I just need to hook up the AD2USB to the NSLU2 and see what I can do with it.
Interested where you go with this
I just got an ad2usb last week
I have perl code reading the ad2usb output then making rest calls to the iSy to set state variables based on zone changes
I will probably make a page on my Linux box that an iSy network resource can call and drive my panel via the ad2usb
Care to share your perl code?
I have perl up and running on the NSLU2.
It's still very rough. I have some junk I need to remove. I struggled with the logic. Will try to have it cleaned and posted bu saturday
I'd love to look at it; will offer help / suggestions on cleanup.
Hopefully this is usable to you. Not much error checking yet. And...obviously need to store things like hostname, passwords, etc in variables.
I put any faulted zones in an array. As we get "ready" messages from the panel, I move the arrays to old and older. Once I have a now, old, and older...I can look at the values and make sure the event actually happened. I really struggled with this logic.
Once an even happens, I run a rest command to update the state variable in the ISY as well as update a SQL table.
I have planned changes to pick up the LRR output to record who armed/disarmed.
#!/usr/bin/perl -w
use strict;
use Switch;
use DBI;
my $database = 'house';
my $server = 'localhost';
my $user = 'insteon';
my $passwd = 'insteon';
our $DB = DBI->connect("dbi:mysql:$database:$server", $user, $passwd, {PrintError => 0} );
open (SERFH, "/usr/bin/tail -f /dev/ttyUSB0 |") || die "Can't tail device\n";
our @active_alarms = (0,0,0,0,0,0,0,0,0,0,0,0,0,0);
our @last_alarms = (0,0,0,0,0,0,0,0,0,0,0,0,0,0);
our @oldest_alarms = (0,0,0,0,0,0,0,0,0,0,0,0,0,0);
our $previous_arm_status = "Unknown";
my $output;
while ()
switch ($_)
case /\[1/ { armed_status("Unarmed"); }
case /\[.1/ { armed_status("Armed away"); }
case /\[..1/ { armed_status("Armed home"); }
case /\[............1/ { armed_status("Armed instant"); }
case /\[...............1/ { armed_status("Armed stay"); }
case /FAULT/ { $output =$_;
$output =~ s/.*FAULT//;
$output =~ s/\s//;
$output =~ s/^0//;
$output =~ s/"//;
$output =~ s/\s.*//;
chomp ($output);
$active_alarms[$output] = 1;
} #switch
} #while
sub armed_status
my $now = localtime();
my $system_cmd;
my $new_arm_status = shift;
if ($previous_arm_status ne $new_arm_status)
sql_update(0,$new_arm_status);
$previous_arm_status = $new_arm_status;
my $j = 0;
foreach (@active_alarms)
if (($oldest_alarms[$j] == 1) and ($last_alarms[$j] == 0) and ($active_alarms[$j] == 0))
print "Delete zone $j $now\n";
$system_cmd = "/home/isy/isy_rest --isy isy99-home-auto --username admin --password 123 /vars/set/2/" . $j . "/0 ";
system ($system_cmd);
sql_update ($j,0);
if (($oldest_alarms[$j] == 0) and ($last_alarms[$j] == 0) and ($active_alarms[$j] == 1))
print "Add zone $j $now\n";
$system_cmd = "/home/isy/isy_rest --isy isy99-home-auto --username admin --password 123 /vars/set/2/" . $j . "/1 ";
#print "$system_cmd\n";
sql_update ($j,1);
$j ++;
@oldest_alarms = @last_alarms;
@last_alarms = @active_alarms;
sub sql_update
my $node = shift;
my $status = shift;
my $query = sprintf "UPDATE alarm SET status='%s' WHERE zone='%s'",$status,$node;
print "$query\n";
my $rows_affected = 0;
$rows_affected = $DB->do($query);
