FTL
  1. FTL started following eisy-ui Alpha release
  2. FTL replied to trevorst's topic in Insteon
    Insteon's website says both Serial and USB PLMs are expected Q1 2023: https://shop.insteon.com/products/plm-serial-modem-interface https://shop.insteon.com/products/plm-usb-modem-interface You can sign up there to be notified when they're available.
  3. Insteon has said they expect to have new Serial and USB PLMs first quarter 2023: https://shop.insteon.com/products/plm-serial-modem-interface https://shop.insteon.com/products/plm-usb-modem-interface
  4. FTL posted a topic in ISY994
    A trivial point, perhaps, but when I create a backup of my ISY994i configuration using the Admin Console (version 5.3.4), the filename includes the day of the week: ISY-Backup.v5.3.4__Sun 2022.09.25 13.56.59.zip Since the default sort on all my folders is Name, this results in the backups being grouped by day name, instead of by date, so it shows all the Friday backups, then all the Monday ones, and so on. Could there be an option to remove the day name from the filename, instead of having to edit it every time I make a backup, so that the backups will automatically sort in date order?
  5. Home Assistant has this on their Integration page: https://www.home-assistant.io/integrations/insteon/ "This integration adds support for integrating your INSTEON network with Home Assistant. It is known to work with the 2413U USB and 2412S RS242 flavors of PLM and the 2448A7 USB stick. It has also been tested to work with the 2242 and 2245 Hubs. Device support is provided by the underlying pyinsteon package." The Python package is on github - has anyone looked at this to see how they're doing the integration using only a standard Insteon hub? https://github.com/pyinsteon/pyinsteon
