spyfish007
Everything posted by spyfish007
  1. I've updated to 5.8.4 and the local admin console has come up. I've tried to back up and I get "Could Not Parse the Configuration File." I am running IoX on Polisy. I have ISY with PLM all connected. I have an internal Zwave/Zigbee card. All communications with devices seem to be working. I was able to do a backup before upgrading from 5.7.1. Any suggestions? Thanks.
  2. Well I've not worked in certs before, so that one is new to me. It worked great! Thanks. The updates now go through. When restarting the services, it had 113 tasks when restarting polyglot! I can now see the dashboard and it already found my ISY. I'll ask Michel if he thinks I should still send it back.
  3. I've heard back from Michel and he asked for uname -a and suggested I contact sales and return it.
  4. I am very frustrated with this new purchase. It has not gone like the instructions at all. I plugged in per directions and no sounds happened and no network connection - even checked my router. There was also a rattle. I took off the cover and the card next to the wifi card was lose. Snapped it in. I also found the wifi antenna connector on the left was loose - tightened it up. Power back up and I got sound, but still not working right. I did a full reset - push and hold till all 3 LEDs show up (really first 2 flash, then the 3rd one by itself). Finally I can see it on my network. I can login with IP address in a web browser. It gets stuck at he login screen. It says I am logged in but the page does not change. I then tried the single quick press for updates and nothing happens. I have ssh via putty. I've done what the wiki says and well well the update and upgrade commands have an issue. sudo pkg update Updating FreeBSD-base repository catalogue... Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: pkg: https://pkg.isy.io/FreeBSD-base/FreeBSD:13:amd64/latest/meta.txz: Authentication error repository FreeBSD-base has no meta file, using default settings Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: pkg: https://pkg.isy.io/FreeBSD-base/FreeBSD:13:amd64/latest/packagesite.pkg: Authentication error Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: Certificate verification failed for /CN=*.isy.io 34378686464:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed:/usr/src/crypto/openssl/ssl/statem/statem_clnt.c:1915: pkg: https://pkg.isy.io/FreeBSD-base/FreeBSD:13:amd64/latest/packagesite.txz: Authentication error Unable to update repository FreeBSD-base Updating udi repository catalogue... udi repository is up to date. Error updating repositories! Please help as this is a very bad experience. I have filed a ticket with UD, but I don't know how long that will take.
  5. Moving to 5.3.2 fixed my issue. Thanks for the advice.
  6. The issue I was describing was the same. I will try out 5.3.2.
  7. Yes this is how I was checking. 5.3.0 all from October 2020.
  8. Thanks for checking. This menu structure is the one I am referencing and yes that is the one missing for me.
  9. I can't even do that. I have old programs with ON/OFF, but I can't create new programs with ON/OFF. It is simply not an option in the UI.
  10. Can anyone help?
  11. I've tried two computers. I believe I have cleared cache on both computers. I have validated the UI is 5.3.0. I'm at a loss here.
  12. Additional info: all entries in "Your Devices" only have options for Query, Backlight, & Write Changes
  13. I upgraded to 5.3.0 and I appear to have most things work again. Thanks for posting such good information. I was going to create a new program and well, when I start trying to add an action to a program, I can't set the value of a scene. Is this a bug or a change in the software? I updated from a really old version (4.8.X I think).
  14. Why would the run program ever come back false? There is nothing in the if condition.
  15. I tried this approach and the retriggering is the same as before. I did take your idea and modify it with a working solution. I am using the disable and enable functionality of a program. Hot Water Request - [iD 001A][Parent 0001] If Control 'Mechanial Room / io.Hot H20 Control-Sensor' is switched On Then Run Program 'Hot Water Run Pump' (Then Path) Else - No Actions - (To add one, press 'Action') New program just for running the pump. Hot Water Run Pump - [iD 001B][Parent 0001][Not Enabled] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Disable Program 'Hot Water Request' $v_hot_water_calls += 1 Set 'Mechanical Room / io.Hot H20 Control-Relay' On Wait 30 seconds Set 'Mechanical Room / io.Hot H20 Control-Relay' Off Wait 20 minutes $v_hot_water_calls Init To $v_hot_water_calls Enable Program 'Hot Water Request' Else - No Actions - (To add one, press 'Action') // $v_hot_water_control is used to keep wait command from retriggering if condition // // * Goal is to no retrigger the pump unless the loop as gone cold // Flow is the following: // A) Sensor triggers start // Run the pump via relay 30 seconds // C) Wait for 20 minutes I think it now works. I might need a program to ensure the Hot Water Request program is enabled at start-up should something weird happen.
  16. Ok so I think read part of the manual wrong. A series of statements within a Then clause (or within an Else clause), up to the next Wait or Repeat statement, are atomic. In other words, all such statements are executed before the conditions of the program are retested. The program's conditions are reevaluated each time a Wait or Repeat statement is encountered, and at the end of each iteration of a Repeat loop. I reread the manual based on your comment. I took it as the IF statement was re-evaluated for sure at the start of the wait. What you are saying is that program has the opportunity to evaluate the IF during the entire wait period. This behavior is certainly giving me issues. What I am seeking is a delay between operations and no allowed re-triggering of the IF condition. I literally want to run this pump for 30 seconds and then sit for 20 minutes regardless of the sensor. Said another way, I want to ignore the sensor for 20 minutes. I welcome help on how to achieve this with ISY programming.
  17. Thanks for the comments everyone. I wish they had put the green status LED after their internal detection circuitry. It gives off a false positive and I was looking in the wrong place - ISY traffic instead of input signal levels. I was also being lazy, so after I got over that and rolled up my sleeves I started figuring things out. I used my EE background, to develop a transistor circuit, because I never like the resistor in parallel trick. I used two resistors and a BJT - NPN transistor to solve the problem. If someone wants me to draw up the circuit, I can. I would have rather used a MOSFET, but I didn't have one hanging around. With respect to the variable in the program and the comment, would you please care to elaborate? My understanding was that the wait commands would retrigger the if statement for evaluation. My flow sensor may or may not still be detecting a hot water call at the time of re-evaluation (after the wait). I don't wish to exit out of the then statement, hence the variable. If the wait does not retrigger the if statement, I would not require the variable. Am I wrong the wait statement? Am I missing something else? I am new to programming in ISY and still getting my head around the structural changes from classic programming languages.
  18. Well I think this is a signaling issue. If I short the sensor input to ground or use 100 ohm resistor, then I get ST 255 and DON signals on ISY. I measured my water flow sensor and the output is 2.2k, which is too high for sensor input. Looks like I need to make an add-on circuit to detect the 2.2k ohm and output a short.
  19. I purchased an IOLINC to control my hot water re-circulation pump. I am replacing my previous standalone controller, because I wanted more specific control that the ISY could provide me. Here is the program I wrote for the control. When I test the Then clause, the program executes exactly like I am seeking, so no problems with it. Hot Water Control - [iD 0004][Parent 0001] If Control 'Mechanial Room / io.Hot H20 Control-Sensor' is switched On Or $v_hot_water_control is 1 Then $v_hot_water_control = 1 $v_hot_water_calls += 1 Set 'Mechanial Room / io.Hot H20 Control-Relay' On Wait 30 seconds Set 'Mechanial Room / io.Hot H20 Control-Relay' Off Wait 20 minutes $v_hot_water_control = 0 $v_hot_water_calls Init To $v_hot_water_calls Else - No Actions - (To add one, press 'Action') // $v_hot_water_control is used to keep wait command from retriggering if condition // // * Goal is to no retrigger the pump unless the loop as gone cold // Flow is the following: // A) Sensor triggers start // Run the pump via relay 30 seconds // C) Wait for 20 minutes So the problems are 100% in the sensor side. The water flow sensor I have does trigger the IOLINC because the green LED on the IOLINC comes on. I can query the IOLINC when the sensor is on and the green LED is confirming the sensor is triggered (circuit is closed) and I always get this response: Sat 01/20/2018 01:54:04 AM : [ 44 34 81 1] ST 0 I don't see any issues with when I go into the extended communicates (level 3), but I am more a novice in that area. My reasons is that hops left never goes to zero from what I can tell. I can paste an excerpt if that would help. The fact that I query the IOLINC sensor manually and still get ST 0 is what has me concerned. So far I have used the restore device and then the factory reset with restore device and still no luck. Please help - I'm stuck!
