killervette
  • Posts
    41
Everything posted by killervette
  1. I will browse through the wiki. I have a lot of ideas on how I want things to function, and would rather have to do it only once.
  2. Ok. I see now. That seems odd to me. I figured once the condition exists, it would execute through the entire then. I changed it to multiple programs. I will try it out tomorrow
  3. My program summary says last run time and last finish time are the same. If Elk Area 'House' 'Alarm State' is Entrance Delay Active And From Sunset To Sunrise (next day) Then Set 'Lights / Study:Study Light' On Set 'Lights / Living Room:Living Room Light' 35% Wait 5 minutes Set 'Lights / Study:Study Light' Off Set 'Lights / Outside:Outside Garage Lights' Off Set 'Lights / Porch Light Keypad' Off Else - No Actions - (To add one, press 'Action')
  4. It seems to work fine now. Maybe an I d 10 t error.
  5. It never turned the outlet off. I will look at the logs if it fails tonight.
  6. If From Sunset + 20 minutes To 10:00:00PM (same day) Then Set 'Outlets / Outside:Outside Outlet' On Else Set 'Outlets / Outside:Outside Outlet' Off So this should turn on the outlet 20 minutes after sunset, and then turn them off at 10pm. Correct??
  7. How can I achieve the following in a program. I want to turn on a light when my elk zone becomes violated. The problem i see is that the program will run continuously when the zone stays violated. I just want to run it once until it becomes normal.
  8. I am running the latest beta. I have a program that turns on a light, waits 5 minutes and issues an off for the light. The light never gets turned off. Any ideas.
  9. Ahh...cache may be it. I forgot I upgraded again and use so many different pcs. I will try that.
  10. 2.8.12. Other than the 10.01 and 10.03 they read the same
  11. so when adding a motion sensor, i go to the bottom of the list and there is 10.01 and 10.03 and they are both Insteon Motion Sensor 2420M. Whats the difference?
  12. Ok, i got them back added. thanks
  13. when trying to add, I get the error - Node not added. failed removing links. Failed writing the highwater mark
  14. java was cleared. I am using the correct url. No icons. Now my issue is I deleted all the motion sensors. I cannot add them back. When adding do I need to press anything on the wireless access point?
  15. I upgraded to 2.8.10 RC6 and trying to add remove motion sensors is impossible. I delete a motion sensor. I go to link a new insteon device. I type the address and choose 2420m. I have Remove Links checked. I hit ok and no popup comes up about holding the set button for 5 seconds. Then i get errors from isy about not being able to write the highwater. Please advise.
  16. I have jumper 5 enabled. ISY is always showing dusk/dawn as on. I am not sure which way to go with the sensitivity. Can someone please explain?
  17. awesome...just wrote a telnet app in vb.net that queries the power status of my Squeezebox Radio and then send a http request to the URL to either turn the keypad led on or off. Now to figure out volume control.
  18. I would like the ability to light up a keypadlinc button by requesting it from the isy99i. Is there a http request I can do to issue commands to isy?
  19. worked great..thanks
  20. I have a keypadlinc with 8 buttons. I have a togglelinc controlling my outside lights. I want button be to control those lights, since A is the porch lights. How can I get the keypad button B to light up when I turn on the lights via the togglelinc. I found this but it doesnt work. I cannot adjust the keypad in the scene. http://www.universal-devices.com/mwiki/ ... ow_Program
  21. Has this been addressed in the 2.8.4 beta release? Do I still have to use a real insteon device?? It basically ties up a $45 device for my setup
  22. So I wrote a RULE in Elk to turn on a light when i disarm my alarm. Then I wrote a statement in ISY that when the light turns on, do something. It will not run. If I physically use the switch, the rule runs. If I use ELK or eKeypad to turn on the light, it will not work. Any ideas?
  23. I want to run a event when I press the togglelinc switch twice in a row. What should my if statement look like? thanks!
  24. So it has to be a real insteon device....i cant my a "virtual device"? I do not have the network module yet. I was waiting to see if i could make this work before buying.
  • Create New...
