SJL
Everything posted by SJL
  1. just wanted to update this thread- I reconfigured the Aeotec Gen 6 range extender for "secure communication" and added another Zwave external switch near the Kwikset 910 and the lock added to the network this time. The distance to the Polisy was only approx 25 ft but the other devices seemed to have made the difference.
  2. Hi Chris, I did not receive any S2 pop ups for the Kwikset lock- I have a GE 40amp relay for my pool pump which did pop up re: security - I declined- and it added fine. The lock just registered and disappeared like the range extender. So the lock and the thermostats are the main issue.. -Steve
  3. Yes - I migrated to Polisy and installed and moved to Zmatter. ISY migration was seamless. Zwave has been difficult - I have followed the threads and upgraged the packages as the fixes were applied. there are no ISY nodes for the Kwikset 910 - It excluded and included similar to the Aeotec Gen 6 range extender but it's not visible in the ISY node tree. The zwave Node count did move ahead. In addition, all of my CT-100 zwave thermostats work fine from the admin console, but UD mobile could not parse data on "inserting Family files for Zwave and mobilinc no longer shows a thermostat tab and in the device tree, there are no adjustable variables (temp, heat/cool etc) for any of the thermostats. I believe the lock issue is related to S2 security and the thermostat issue now likely due to the daughter subentries for each zwave thermostat. None of these were issues with the 300 and 500 zwave boards.
  4. Kudos to Michel and the team for all of their hard work in this roll out. I was able to upgrade to 5.50 and with the new fix- the zwave nodes now show up for most of my devices in the tree. My Aeotec gen 6 range extender registers but does not show up as a node as others have described. The problem is - the same is also true for my Kwikset 910 door lock. It registers but there is no node to set parameters. I have excluded and included it 2 additional times- no change. I think this is an issue with S2 security mode - Is there a fix for this?? -Steve
