sndflea
  1. sndflea replied to sndflea's topic in ISY994
    I have reviewed the web pages on the Polisy but am uncertain as to how it solves the PLM problem. How does the Polisy interact with the Insteon devices. I still run some legacy X10s. Will it also work with them?
  2. sndflea posted a topic in ISY994
    I am currently running an ISY994 with portal access at my home and an Insteon Hub at my Beach House. With the demise of Insteon, I will need to replace the hub. Assuming I purchase an ISY for my Beach House, do I need to add another portal account or can I add the new location / ISY to my existing portal account. Do you know if the Insteon PLM is still available and if so at what price. Thanks, Sal
  3. sndflea replied to sndflea's topic in ISY994
    Thanks everyone for the advice. I will try the factory reset and taking the switch out of the system and direct wire the light (or put in a traditional switch). I also have a z-wave switch that I will try.
  4. sndflea replied to sndflea's topic in ISY994
    1) Not sure how to factory reset the device 2) I can only turn the lights back on if the floodlights are off. When the outside light turns off, the LED on the Togglelinc stays off - as if the outside light was actually still on. I believe that, in addition to being on separate circuits, that the floodlight breaker and the breaker of the togglelinc are on separate busses. There is no photocell involved. Strange as this circuit has been set up for some time. I did recently have a new heat pump installed and that involved moving some breakers around in the box but I don't believe these two circuits were involved.
  5. sndflea posted a topic in ISY994
    I've had an odd issue crop up. I have a Toggle Link controlled through an ISY program turning on / off an exterior light . Has worked fine for quite some time. Recently it stopped coming on. The light on the controller was off so apparently the ISY and Toggle Link thought it was on. If I fiddled with either the toggle on the switch or tried turning it on from the ISY it would eventually come on. Turning off from the programming was never an issue. Trying to figure out the issue I rebooted the ISY and everything seemed to work fine. The controller is in a 4 gang box. Switch next to it (not a smart switch) turns on the floodlights. Last night I noted that if I turn the floodlights on, the light controlled by the Toggle Link turns off. Turn the floodlights off and the light comes back on. They are on separate circuits. Any ideas? I was going to replace the Toggle Link but try finding one. They are as rare as Hens Teeth
  6. sndflea replied to sndflea's topic in ISY994
    Thanks everyone. Got the switch up and running
  7. sndflea replied to sndflea's topic in ISY994
    In the Admin Console I can see the option to add a device and to remove a device that has been added. How do I exclude it?
  8. sndflea replied to sndflea's topic in ISY994
    I am running 5.30 on both. With the bench set up the switch was no more than 5 feet from the ISY
  9. sndflea posted a topic in ISY994
    I've been running Insteon and X-10 for years but have no experience with Z-Wave. I've added the dongle and the module. Trying to add an Enbrighten Toggle Switch. First thing I did was do a factory reset of the dongle. Next clicked Add Z-Wave Device. Window pops up searching for device. Directions for Enbrighten say to press up and release the toggle to add it to the network. ISY never sees the switch. I did a bench test and put the switch right next to the ISY and it still doesn't see it. I have read the documentation for ISY / Z-Wave and thing I have done everything that I should have to get it set up. What am I missing? Thanks.
  10. sndflea replied to sndflea's topic in Amazon Echo
    No - I forgot all about the portal. I made the changes in the administrative console and thought that would do it. Thanks - that solved it.
  11. sndflea posted a topic in Amazon Echo
    I have had Alexa set up with my ISY and working well. I had a switch go bad and replaced it. I reprogrammed in the ISY and it works fine. When I rescan for devices in Alexa it keeps coming up with the old device. I "Forget" it and rescan but it continues to come up with the old device. Device name for the old and new switch are the same but renaming it does not help - Alexa continues to see the old switch and not the new one. Any ideas? Thanks
