MMAltair
  1. I ran into the same problem. Lost my favorites associated with the my Z-Wave door locks. In addition (as stated in other posts) the Z-Wave lock information no longer shows up in UD Mobile. I ended up creating some programs to monitor the conditions of the Z-Wave locks and translate this information into some state variables for use in UD Mobile Favorites. A bit ugly but this work arounds works. Mike
  2. The Mapped Status problem seems to be fixed in IoX ver. 6.0.3. Once I did this update and restarted the affected Plugins everything is back to normal. Mike
  3. Thanks Paul. I wasn't aware that a precision could be assigned to a variable and will follow your directions to fix my problem. This new knowledge opens up a bunch of possibilities including better handling of Yolink temperature values which currently are being rounded to the nearest integer. Thanks again! Mike
  4. I installed one of the Emporia Smart Plugs in order to monitor the on/off state of an HVAC ventilator unit. The thought was I could periodically check the power consumption through the Vue plugin and see how many watts were been drawn to determine the operating vs standby state of the unit (the ventilator is controlled by a complex algorithm in the HVAC control system which I can't access from EISY)). My plan is to monitor how the HVAC algorithm is actually controlling the unit since I suspect it is less than optimum. The problem I'm running into is the Current Power Consumption value in the node is in kilowatts but the ventilator only draws 170W while running and about 10W in standby. The node shows this as a decimal value (0.1763 KW operating or .0112KW standby) but this translates to value of 0 when I attempt to use the value in a program or to assign it to a variable (all variables are signed Integers in IoX). Is there anyway around this limitation? What would be really helpful is if there were another field in the Node that also displays the current power value in watts. Thanks Mike Operating Mode Power Standby Mode Power
  5. I ordered 1 of the Yolink smart plugs and 2 of the Emporia Vue smart plugs and will experiment with both of them. Thanks for all the replies. Mike
  6. I'm doing a bit more research now before going down the Yolink path for energy monitoring. I read some of the reviews on Amazon and people are complaining that the Yolink Smartplug (6602) only updates the energy usage once per hour. This is too long of interval for a device that turns on/off more frequently than this. Do you know if the Alarm Limits trigger an immediate update to the Yolink Polyglot Plugin when the limit is exceeded (in either direction)? Thanks Mike
  7. I'll give your technique a try. I haven't purchased the smart plug yet but can experiment with one of my Yolink temperature sensors as an alarm source while I wait for the smart plug to arrive. Should be an interesting project. Thanks for your comment. Mike
  8. I don't think I need any averages at this point. I'm trying to get a better idea how much my heat recovery ventilator is running. The ventilator is controlled by an algorithm in my HVAC system which factors in things like outside air temperature and indoor humidity along with a windows efficiency setting to prevent condensation on the windows (something that is a problem in Minnesota in the winter). As long as I can get a sense for when the ventilator is running, by measuring its power consumption, I should be good to go. As long as the current power consumption is reported I should be able poll the node at a regular interval and determine if it is on or off and then calculate a percentage of on time. Thanks for the quick response. Mike
  9. Does anyone know if the Yolink Energy Monitoring Smart Plug works with the Yolink Plugin? Does the real-time energy usage get reported or do energy usage limits get reported? I'm dipping my toes in some limited energy monitoring and need to decide what path I take. Yolink has become my go-to place for moisture, temperature, and humidity monitoring due to its wireless communication reliability. I have a specific need to monitor an HVAC HRV and thought the Yolink Energy Monitoring Smart Plug would be an easy way to integrate this with EISY. Thanks Mike
  10. Okay, that fixed it. Before 6.0 I didn't need to explicitly set the displayed text in Advanced Status. Thanks for the response! Mike
  11. I just updated to IoX 6.0 as well and ran into the same problem. I use the Alarm system status (Disarmed, Armed, etc.) in my Favorites to show the Armed status of the system and it use to show the status as Armed Away/Armed Stay/Disarmed/etc. Now it only displays a number. This problem would be solvable using Advanced Status except there is no way to do a comparison against the number value that is returned. Mike
  12. 2) Update. I tried the comparison approach you proposed and that works as described. Thanks! Mike
  13. 1) I thought the back arrow had worked at some point. I'll be patient. 2) I considered this approach but wasn't sure about the order of evaluation. The wiki entry explains this (I should have check the wiki first). I'll try this method and see if I can get it to work. Thanks
  14. First, I use UD Mobile and EISY extensively now days to manage most of my IOT devices and for the most part it is great. I have two questions/requests. 1) I use folders in the Favorite area to provide a top level view of things with the ability to drill down into subfolders when more detail is needed. For example I have two EISY systems (one in our main home and one in our cabin) so I have two folders at the top level in Favorites, one for each house. When the Folder is pressed for either system it opens a top level page that contains important details for each system along with more folders that can opened to drill down into the details. The goal is to keep the opening page for each system limited to one page so it can be viewed without scrolling. The opening page contains things like Alarm system status, buttons for kay lights, the state of various doors/windows, and folders to drill down into things like door locks, temperatures, more light controls, water sensors, etc. So far this all works well with one exception. When the back button is pressed in any sub-folder it always goes back to the Devices and Scenes area of UD Mobile instead of returning to the parent folder. Is this be design or am I doing something wrong? If it is by design is there a workaround could be implemented? It would be way more convenient and intuitive if the back button returned to the parent folder. 2) Expanding on the 1st topic I also use the Advanced Status Configuration settings to control the color/icons/Info displayed on many of the buttons and folders. For the most part this meets all of the needs for conveying information concisely for the buttons and folders. The one exception I have run into is that the Advanced Status Configuration is only able to use the Node defined in the Favorite, that it is associated with, for its comparison function. I have some situations where it would be real handy to be able to specify the node that the Advanced Configuration Status uses for the comparison. For example, I have temperature buttons for various temperature sensors where each of the buttons shows the actual temperature in its status field. I then use the Advanced Status Configuration for each button to changed the color of the Icon to show weather the temperature is out of range for that sensor. For some sensors this is 3 states, High, Low, and Normal. This can be calculated easily in a program and assigned to a variable but if this variable is used for the Favorite then the actual temperature can't be displayed. It would be real handy if the node used for the Favorite and for its associated Advanced settings could be selected independently. If there other ways to accomplish this I'm open to advice. Here are some screen shots of several page configurations I have set up - Top Level - The 2 houses 2nd Level - PF (Home) 3rd Level - Temperatures Folder
  15. Ross, I have an EISY system at IoX release 5.9.1. The release numbers I mentioned before (1.5.16 & 1.6.2) were for the Yolink plugin version. Mike
