ultrajones
  1. Okay, then something else is wrong. I don't have an option to delete... just disable and pressing delete does nothing. Any help would be appreciated.
  2. How do I delete the Insteon Leak Sensor and the Insteon Mini Remote? I have no options to delete them in the interface. Regards, Ultrajones
  3. The "all lights" device is no longer appearing when I import my lighting devices into my Elk. Any idea how I can get it back? I don't have the Disable All On/Off checked. Regards, Ultrajones
  4. I installed this update and found something a bit odd. If I don't have the Elk module, why does the ISY: 1) Query for the zone voltage for all zones even though they are not defined as an "Analog Zone". 2) Query for the temperature of all zones 1-16 even though they are not defined as a "Temperature" zone. The output of these queries is causing issues with other applications connected to my Elk M1XEP module. Regards, Ultrajones
  5. You were right, I was wrong. I needed to delete and readd the devices under 3.2.4. Wish I knew this 6 hours ago Thank you for your help!
  6. I believe I finally determined the root cause. Once I moved my ISY, the Outletlinc On/Off units started responding to the screen on/off. This really doesn't make any sense as I was able to turn them on/off directly from the ISY.
  7. I just installed 4 On/Off Outletlincs and none of them are working as expected. I can control them individually and the screen indicates they are on/off, yet they do not respond to the scene. For comparison, the Outletlinc dimmer versions work fine. What am I doing wrong? I tried the latest official ISY firmware and the very latest beta and I am seeing the same issue. Regards, Ultrajones
