Update Bricked my eisy
It is a brand new eisy Device. I was updating it and the old Polisy prior to a migration to get them on the same firmware prior to migration.
@Geddy Thanks for consolidating everything into one place. I think I opened the other threads on accident. I have been talking with Michel through the support ticket and will update this thread when I have a solution. Thanks for the help.
it is not requesting DHCP from my router / not being assigned an IP address. SSH does not work I tried a second reboot but still not working. not sure what version the old firmware was. I tried clearing my java cache and using a new launcher it still does not show up.
Just opened a ticket. Thanks for the suggestion.
I did the update and now my IoX seems bricked. It is not showing up in the Admin Console finder or is it being assigned an IP address through my router. I am able to access it through https://eisy.local:8443/desc only. When I do I get a long error message. I have attached a picture of the message below. I also tried factory resetting it by pushing the button 10 times then 5 and nothing changed. Any help would be appreciated!
All Nodes not Connecting - Any help appreciated!
@Geddy Thanks again for the help. I tried all of these things and PG3x is still having issues. I have the eisy arriving soon, hopefully after the upgrade to the new hardware everything will be working.
Hi, Thanks for the help. I was able to upgrade to PG3x and also update the controller as well to the latest version. PG3x is now super slow and very unresponsive. Also only one of my node servers is connecting and working. I have been wanting to upgrade to eisy from polisy so figured I would take this opportunity to upgrade and have an eisy on the way. I attached a screenshot below of the new PG3x interface showing only one of the nodes connecting. I tried running the reinstall all plugins but it did not fix the plugins that are not connecting. Tried a reboot also. Also I am unable to install any new plugins from the store or see my purchased plugins. Thanks, Matt
Hello Everyone, About 2 weeks ago all my nodes stopped connecting and only show disconnected. I have tried reinstalling my nodes and physically restarting the Polisy but nothing has worked. I looked at the logs and Polyglot v3 seems to be caught in a reboot loop. I have attached my logs and a screenshot below. Any help would be super appreciated! Thanks so much, Matt pg3_12-7-2024_63207-PM.zip
OAuth error showing devices
Having this issue also. I am able to connect remotely but the status does not show for any of my Insteon devices. This started about a week ago.
ST-Sonos Failure
Having this issue as well. The node server fails about every 1-2 weeks and a restart fixes it temporarily. Attached my logs below if it is of any help. ST-Sonos_5-27-2023_121009-AM.zip
Reset ISY on Polisy
@Michel Kohanim Just sent you a Direct Message.
Reset ISY on Polisy
@Michel Kohanim I am having the same issue as @DirkM where the portals tab is not showing on my ISY instance on polisy. When I use manage modules on the ISY it does not show portal. Can I send you my UUID?
Insteon 2448A7 + RaspberryPi + ISY994?
If anyone would be willing to sell a working version of this in an enclousure I would be willing to buy one. Not currently able to make one of these myself.
ISY Scenes - Apply Changes to All Devices Button
@lilyoyo1 There is no need to disable previous functionality for v5 to work properly. It would have been trivial to add a button that applies specific changes globally for a certain device type such as lighting or specifically Insteon devices or all devices matching a certain criteria. This is a feature that I am sure would be used by many as a lot of people have voiced complaints about this feature being omitted. You also mention the possibility of staying on the 4.0 branch but when I received my device it was already on v5. If I had known of this crippling limitation I would have second guessed my ISY purchase. It also seems silly to disregard all the other positive changes that were made in v5 and downgrade to v4. Although, there is no need to harp on the past because there is little chance that universal devices will add this feature back since it looks like they have intentionally removed it. @TrojanHorse I as well would love to see a plugin developed and would 100% be willing to pay for this functionality. Unfortunately I don't have the time currently to do this or I would build the plugin myself. Hopefully someone will make this a possibility.
^ This. There should at least be some way to globally apply changes to a scene it seems silly that the programming team behind universal devices thought that their customers wouldn't notice such a huge loss in functionality. If you have a significant number of devices in a scene this change makes it very difficult to modify those scenes.
matthewjocko
Joined
Last visited
