Chris McKean
  1. How will we know when the scripts and instrucrtions are updated?
  2. Left for about 4 hours and when I returned home it is now working.
  3. Still no joy. Upgraded to MyQ node version 3.2.23 and PG3x version 3.2.10. Getting 429 Client error: Too many requests....
  4. In regard to the question about whether I have special characters in the password, the MyQ app requires at least one symbol in the password. What do you regard as a special character? Are there symbols that you can use in the password that won't be a problem?
  5. I have had the same error after upgrading PG3x to 3.2.9 this morning. I am running the latest version of the MyQ node server. I stopped the nodeserver and waited 40 minutes and then started it. Still getting the same error. You said to shutdown the node server. Is that the same as stopping it?
  6. I have upgraded to the new release, but after the upgrade, it shows that the current version on the ISY dashboard is still at version 3.0.22. I have tried stopping Kasa, upgrading then starting the node. It shows the current version is 3..1.0 after the upgrade, but when I start the node server, it reverts back to 3.0.22. Am I doing something wrong?
  7. Just converted to Eisy from Polisy Pro yesterday. Conversion went fairly smoothly. Question, is there a way to determine the utilization of memory, disk, and cpu on the Eisy?
  8. Waking up the devices as documented in the manual fixed the problem.
  9. They are both battery operated. They seem to be working (nodes display the proper information), however all the nodes need changes to be written. It appears that I am not able to wake up the devices. "Keep awake" is on, but "is awake" is false. When I query the device, the "is awake" changes briefly to True, but then I get an error saying request failed.
  10. Yes, it is a Polisy Pro with the ZMatter board installed.
  11. I have two Zwave devices, a ZSE40 and a ZEN34 that display in the Polisy as if they need changes to be written to the devices. I have executed "write changes" with no effect as well as under zwave "rewrite all device links". Neither one updates the display. All of my other Zwave devices appear normal in the Polisy Main menu. Any idea how to fix this?
  12. Upgraded to 5.5.4 and the Zooz Zen34 still not working correctly.
  13. My configuration until recently was an ISY 994i ZW+ IR PRO and a Polisy PRO running PG3 nodes servers. I moved off of the ISY 994i onto the Polisy Pro. So, now everything is on the Polisy Pro. Once the ZWave/Zmatter board is stable for all my Zwave devices, I'll buy an eisy and move everything over to it and get off the Polisy Pro. Since UD has announced dropping support this year for the ISY 994i, I'm sure that the Polisy will not be far behind. The 994i has been a great controller, but the weak link has been the microSD cards. I've had two microSD cards get corrupted and had to rebuild. The remote control for the all the fans uses a single button to turn on and off the light. So, I'll probably not do anything with the lights via programs. With what you described regarding sync problems between the bond bridge and the remote control, it looks like more headache than it is worth. However, I can do some programming around the fans now.
  14. Here is the log file. The fans and lights respond briskly now in IoX. Before I rebuilt them in the bond bridge, if they responded at all, it was only after 6-10 seconds. I think this is going to work. Thanks for your help. pg3_1-18-2023_111415-AM.zip
  15. I just finished rebuilding all of the fans in the bond bridge. Didn't see your request for a debug log file until just now. I am going to delete the bond node server, reinstall and discover all the devices. I will put it in debug mode and send you results of the discovery. Don't know if that will help you or not. After I rebuilt the first fan in the bond bridge, it works reliably in IoX, so I am hopeful that this will fix my problem. I'll send another reply with the log file in it.
