kevbo
  1. @Javi What I do is on a 'motion at front door' get ISY to send me a text of the link to an IP camera. That link in my text would auto populate a single frame in my text. If I was lucky and the person was still standing there at the time I got the text and opened, and I could see image of the person in my text. However, if they were fast, walked up and did a delivery, I would see no one because of the lag. If a tile had the ability to show the first image URL of the IP camera, you would essentially see that first frame. Then 'theoretically' just need to allow for a trigger to freeze that image. At that point if you selected the tile, it would just open the camera. I use SWANN NVR cameras...with an app called Swann Security. I couldn't find any information if it has a URL.
  2. Hello! just started using this, and like everyone else think it’s great and the team is doing a great job! A couple suggestions - Allow the tiles to be sized… it would help in organizing ‘like’ devices in favorites. For example I have four tiles that show temps in house…would love to fit them a little smaller on same line. Using color is great and love it. - next suggestion is around integrating security cameras and would require a node server to be built. Would love to have a node server be able to capture a single image from an ip camera on motion. Save the image and use that in the Tile. Selecting that tile opens an external program for your cameras. Just trying to think how security cameras can be linked to in a meaningful way.
  3. kevbo replied to pjjameso's topic in ISY994
    Ya, so weird...it just doesn’t work.... i have tried setting gps to ‘always’ and that still does nothing. i am using an iPhone 6...but I can’t see why that would make a difference. The testing through the app works fine, so I know it’s setup correctly. I may try some different iPhones.
  4. kevbo replied to pjjameso's topic in ISY994
    Thanks PurdueGuy, When you go into the geofence that you added, does map show a red or green ring around the pin? i was under the impression that when you are ‘home’ in your geofence, it would turn green... mine is always red... My ‘get’ tests work fine... Thanks kevin
  5. kevbo replied to pjjameso's topic in ISY994
    Has anyone tried locative with iOS 12? I have tried locative, it locates where I am, but never goes green. Tried resetting phone, etc...no luck. Made the radius as big as it will go, but still no green.... Are there any other options available? Thanks Kevin
