Niccolo
Everything posted by Niccolo
  1. Niccolo replied to Niccolo's topic in ISY994
    Good advice.
  2. Niccolo replied to Niccolo's topic in ISY994
    Thanks, Brian.
  3. Niccolo posted a topic in ISY994
    I have an ISY 99i with an Insteon PLM that is a few years old -- not the new dual band model. My programs have stopped running and I can't get remote access. If I unplug the PLM for a while, it will work again for a while. Is there a way to tell whether I need to replace the PLM? Could it be something else? Will the new dual band PLM unit work with the ISY 99i? Thanks in advance for the help.
  4. Excellent. I'm always happy to help. -Xathros Glad to have your help. Seems to be hanging up again, though. Just the iPhone. Maybe a hardware issue?
  5. 3G 5.1.1 Since following the steps you suggested, it seems to be working now. I'll monitor and keep my fingers crossed. Thanks again for the help. Niccolo
  6. That would seem to indicate that the problem lies with the iPhone and more likely Safari. Some Ideas/things to try: 1) Reboot iPhone - Hold Power+Home Button until you see a white apple on black screen. - Test. 2) I wonder if your iPhone has a saved username/password for your ISY that may be causing this trouble here. You can clear those by going into Settings / Safari / AutoFill / Clear All. - Test again. 3) Try clearing the cache/browser data. Settings / Safari / Advanced / Website Data / Remove All Website Data. - Test again. 4) Try an alternate browser like Perfect Browser. -Xathros Thanks! I am working my way through. How do you download an alternate browser? Do you have to go to the Apple download store?
  7. None that I am aware of. I usually just exit the browser or go somewhere else. I don't use this method very often as I use Mobilinc for most all of my remote access to ISY. I did need to accept a new certificate when I tested yesterday. You might try clearing the cache and browser data on the iPhone and try again. (Settings / Safari / Advanced / Website Data / [Remove All Website Data] -or- [select edit and remove only your ISY address if you don't want to clear everything] ) Are you connecting via local network on WiFi, Remotely via DynDNS/Port Forward on WiFi or Remotely via 3G/4G ? -Xathros Remotely via 3G. iPad is DynDNS, but not problem there. Just iPhone.
  8. https.
  9. Xathros: Thanks. I have it working intermittently. Is there a recommended "off" or "exit" procedure that I am not following that is perhaps hanging it up? Niccolo
  10. Thanks! Michel: I am having a weird issue with 3.2.6 and iPhone. When I link to the site I get the blue UD screen and "Load config," but no panel asking for user ID and password, so it never actually connects. This does not happen on computers or iPad. Just on iPhone. Any ideas? Thanks. Niccolo
  11. Upgraded from 3.2.5 with no issues. Elk is now working again!! Thanks! Niccolo
  12. Thanks!
  13. Thanks. Is this something I need to download or adjust or an adjustment at your end?
  14. Michel: I have downloaded the upgrade and have set ELK to show in setting. But when I click on Elk, I get the message: "ELK Rest comment failed, checking Elk status." I have tried reset and refresh, but nothing further. What do I need to do? Thanks. Niccolo
  15. Got it loaded after several "fails." I have ELK showing, but when I click on it I get "Elk Rest command failed. Checking Elk status." Nothing further. Niccolo
  16. Michel: It keeps failing with the folowing messages displayed: "Upgrade Failed: Failed uploading file (reported written size is invalid)" "Socket Open Failed javasets Socket timeout Exception" Niccolo
  17. Michel: Great news! Thanks. Niccolo
  18. Michel: I have an iPhone, so Java won't work. How do I go back to the previous version? Thanks. Niccolo
  19. Good news! So I will just upgrade when it comes out on the admin screen and that will fix the problem? Thanks. Niccolo
  20. Will do. Thanks. Michel: Any news? Thanks. Niccolo Will do. Thanks.
  21. Will do. Thanks.
  22. Thanks, Michel. How do I do that? Niccolo
  23. Prior to the upgrade, I could go to the URL and be able to arm or disarm from my iPhone or iPad. I cn do it from a reguar computer, but obviously being able to do it - and check status -- from the iPhone is a major benefit. Is it possible to undo the upgrade?
  24. Thanks, Michel. Niccolo
  25. I just upgraded and now my iPhone and iPad will no longer get me to the admin console to check Elk security. I was able to download the admin console on my Mac, but iPhone and iPad won't open a Java file. Any solutions?
