Tommy James
  1. Not being technical and not being a developer I have no idea what would be involved in this request. With that said is Apple CarPlay something that is on the future roadmap for the UD Mobile application? If not, I’d like to throw it in for consideration. I could see having a few buttons for devices on my dashboard would be very convenient.
  2. +1 on same error message
  3. Thank you for confirming.
  4. Is there a confirm request button option in UD Mobile? I'd like to have a solution where, when I exit my geofence, I get asked if I want to shut my garage door. There are times when I do not want it to close just because I left the area. For example, if a kid is out playing and doesn't have a device on them.
  5. My experience is that when the GDO stops working it comes back on it own after a short time period which usually involves us using the physical remotes and wall buttons but for whatever reason the codes sync back up and everything works again. My theory, from reviewing the logs of the GDO, is the rolling codes get back on track from the utilization of the physical buttons. The door that gets used several times a time a day sync back up very quickly and the other door takes longer because we don't use it that often. My GDOs stop working during power outages, wifi issues or EISY reboots. Hope this helps and see if a few physical button pushes and a bit of time help you guys.
  6. Hey guys, I did some research on this back when I first posted but haven't really look at it since. The assumption is it is still the same. As alizer has pointed out, the URL from our logs has a 2.5 in it and the documentation from OpenWeather wants a 3.0 in it. @alixer if you replace the 2.5 with a 3.0 in your link and submit via your browser you will get a set of results. Hope this helps @bpwwer
  7. Apologize if this is covered somewhere else, I couldn't find it if it was. Mostly curiosity, I was wondering if EISY has any capacity limits / maximums for devices, programs, folders, etc, etc... I'm running on a 1TB NVMe in high performance and no redundancy mode if that changes the answer.
  8. Thank you! Sorry to the bearer of bad news; at least we know for future users. I (we) appreciate you developing these weather node servers. I use them a lot in my automations. Thanks again!!
  9. Thanks Bob, however I have bad news for new 2.5 users. I still could not get it to work so I submitted a ticket; here is the response from Openweather: ”One Call 1.0 (2.5) is deprecated for all new free and startup users. We recommend using One Call 3.0 as a modern and updated version.”
  10. Hello everyone, I've just installed the OpenWeather node server and waited for the API to activate, which it has successfully done. However, I seem to be encountering an issue where although I am connected, no data is flowing through. It appears that there might be a versioning issue. When testing the API using the URL method, version 2.5 returns an API error, while version 3.0 returns the expected data: http://api.openweathermap.org/data/2.5/onecall?exclude=minutely,hourly&………………….. I've extracted the truncated (for privacy) link above from the NS logs. All the documentation from OpenWeather specifies using version 3.0 in their URL. Interestingly, when replacing the "2.5" in the NS error link above with "3.0", it successfully returns data. Has anyone else encountered a similar version discrepancy with this API? Any insights or suggestions on how to resolve this issue would be greatly appreciated. Thanks for your assistance!
  11. Hello, I'm seeking assistance with the Ratgdo plugin. I “believe” I've carefully followed the instructions provided by Goose66 and Paul's site, as well as reviewed numerous forum posts. However, today I'm encountering an issue where there's no response to commands. Yesterday, I completed the installation on two openers, and everything was working perfectly fine. I could issue commands such as open/close, turn lights on/off, and monitor motion status changes both from UDI Mobile and the Admin Console interface. The only notable difference was that UDI Mobile displayed "1" and "0" instead of descriptive labels like "open" or "closed," whereas the Admin Console interface showed the labels properly. Today, I can see word labels on both the Admin Console interface and UDI Mobile. Additionally, if the status changes via traditional buttons or motion is detected, I can observe those changes being reflected. However, commands issued from either the Admin Console interface or UDI Mobile do not produce any action. Should I expect to see a command when monitoring the level 3 log in the AC of EISY? If so, there isn't one present, but I can see log entries in PG3 when a command is sent from either the Admin Console interface or UDI Mobile. I restarted the Node Server, but I have not deleted the nodes and re-discovered. Goose66, I’ve DMed you a screenshot of my ratgdo configuration and the debug logs from PG3. I’m utilizing the included MQTT with EISY. Any assistance would be greatly appreciated.
  12. +1 Worked great. Eisy is flying!!
  13. I had to disable and re enable the skill to get it to work. Thank you!!
  14. When I look under My Profile in the portal, I do not have a way of linking my amazon account per the instruction on the forum and the wiki. Believing I need my user email and amazon account emails to match, I added a user with an email address that matches my amazon account email; my initial portal setup user is a different email address and the link option is not in either of my user accounts. Both are set for admin rights. I have tried removing my ISY and reconnecting to the portal with no luck. Clearing cache and using a different browser have not helped either. I'm using a trail license if that matters. Thoughts and thanks!!
