atomicboy
  1. I followed the instructions to the letter and updated. Everything came back and seems to work great however I am uncertain how to determine I have the new functionality. Where do I check and what should it be? Thanks!
  2. I installed the beta and did a reboot. During this I got a number of bogus notifications.
  3. I just gave it another try and it worked. I ran both the ssh commands and it is restarting now. Did 6 button shutdown. Restarted. Got the same message that PG3x needed to be restarted. Rebooted inside MobiLinc. All is good now. As an aside: I was very quick with the copy paste and it immediately required the password again.
  4. I tried a few more times and again I still got “Not Found”. To ensure no typing errors I copy pasted as well. I am not that much of an experience user of ssh commands, so maybe it is me? I was a bit surprised when I typed in “sudo pkg add -f https://pkg.isy.io/udx13.staging/All/pg3x-3.1.35.pkg” that it prompted for the password (“admin”) again. I do not believe I experienced this before. I am just identifying this in case I made an error.
  5. I tried twice and got “Not Found” as well.
  6. I kicked off the update and when finished I cleaned out Java and reloaded Java. Logged back in an did a reboot. Everything is running great. I really like that my Eisy is running very stable these days. I had to replace a failing Serial PLM about 2 months ago because it was not communicating well with my Insteon Leak Sensors and throwing errors in my monitoring programs (missed heart beat, etc).
  7. When I migrated from ISY994 to Eisy I had a similar issue. I had originally used Mobilinc HD which requires the Alexa spoken word to be stored in each device notes field. The migration program in the UD Portal does not migrate the note field but does migrate the Spoken Word field in the UD Portal which in my case these fields were empty. So the behaviour when using the Eisy appeared like the PLM was not working but when I went back to the ISY994 the PLM did work. I entered the Spoken Word in the UD Portal for each device and the Eisy works perfectly. So if you used Mobilinc HD, maybe that is the problem?
  8. I appear to have everything working including PG3. I got PG3 working by power cycling my Eisy.
  9. I am using a Ubiquiti Unifi Dream Machine Pro and most of my network is Unifi. I have been able to set up UD Mobil, my portal is correct now, wifi and wired working to the Eisy. Yesterday PG3 would not allow login but since I got things working in UD Mobil (I think) I have not tried PG3. Will try later today. I just now tried PG3 and was not able to login. It flashed up the portal login screen (which I logged into) and then flashed up the PG3 login screen. I tried the default passwords and other associated passwords but no luck. I will keep watching the forum and continue to experiment as I am not in a rush. My ISY994 continues to function well.
  10. Sounds like my experience as well. iPad OS 16.2
  11. I used the Admin Console after formatting the SD Card.
  12. For my issue I had to go further and reformat the SD Card and reload the FW. I am not saying I know enough to advise you that this is your next step but for me it was the only option I had left.
  13. That is the extent of my knowledge on the topic.
  14. atomicboy changed their profile photo
  15. This worked for me this morning.... please see attached file.
