mbski
Everything posted by mbski
  1. Hello, I have tested isy on polisy, mainly scenes, programs, and devices, which are working great. Thanks UDI team. I have not moved anything over from my current isy box. So, I have a few questions. · Currently using no Z-wave devices. · Current isy box version is 5.016C – 2413S plm · Current isy on polisy 5.04A – 2413U plm 1. Once isy box and isy on polisy have the same version #s, could a back-up from isy box be restored onto the isy on polisy? 2. Can you run P3 on the isy box? 3. If P3 can run on isy box, what version # is required? 4. Can you run P3 on 2 separate isy’s at the same time? 5. Would you recommend I update isy box to 5.3.4 test build? Thank you in advance,
  2. Install successful except UD mobile IOS hangs at “getting program files from ISY” Removed all nodes, restarted UDX and isy. Tried rebooting as well. UD app version 0.37. EDIT: Thank you @Michel Kohanim yes I did not have a program.
  3. Once ISY on Polisy is public you can use that 2413U PLM. It is currently in alpha testing, which means beta will follow soon. You will need to buy a Polisy. You might find someone who has an extra 2413S and see if they will part with it, as some have migrated to Z-wave. There’s been a lot of talk about the serial PLM being discontinued. Just a few suggestions.
  4. FYI, Whywork, I was not replying to your issue.
  5. You can purchase on the isy portal https://my.isy.io/index.htm Then go to AC for ISY in polisy and select config tab, then portal tab, click the auth. Then ISY will re-boot and the selected ISY will show green in the portal.
  6. Updated 3.1.12 and purchased and installed Elk module. System was sluggish and locked up. Had the port # set to 2601. Switched to port 2101, and now I'm good. As others have already stated, Elk responds from ISY, but ISY does not show status. Just wanted to post about the port # importance. So far I am very pleased with the modules capabilities. Thank you UDI
  7. I'm needing a good explanation of how to link a remote link to turn on and off ventstar with v-2, how to control heat and cool, and how to control temp up and down. Program with ISY-99 Thanx Mike Bell
  8. mbski replied to mbski's topic in ISY994
    Well very strange, this happened all of a sudden no upgrades or changes, but today I can access just fine???? very strange. just to note leds on back were blinking like normal when I could not access it. thanx for the help Mike Bell
  9. mbski replied to mbski's topic in ISY994
    The normal one green lite.
  10. mbski posted a topic in ISY994
    I can't access isy from local computer, can't find it on my network either, I've unplugged it, reset it and no luck. Please help Mike Bell
  11. What would you recommend? I'm not liking that hum either! Thnx Mike B.
  12. Does anyone use a dimmer for ceiling fan speed control? If not please explain Thanx Mike B.
  13. mbski posted a topic in ISY994
    i would like to know if anyone has been able to use pentairs protocol adapter, for home automation, with the ISY-99. this is for a pool and spa control. thanx mike
  14. mbski replied to mbski's topic in ISY994
    The problem was centered around a bad ethernet switch. I swapped with another switch and now 2.7.7 alpha completed successfully. thanx to excellent tech support at universal devices! Mike Bell
  15. mbski posted a topic in ISY994
    Im tying to update my firmware to 2.7.7 alpha, when i try it wont complete. and i get message. ;java.ioexception: an established connection was aborted by the software in your host machine, Im using windows vista and all firewall software is off, and my isy99 current version is 2.7.0. can anyone help? thanx Mike
