WFP
  1. My Schlage BE469ZP locks, (all six!) are all doing the same thing... I never manually upgraded my EISY to 6.0.3, but somehow it was upgraded while I was away for a couple of weeks. There was a reboot buring that period. I am now being told there are still more upgrade packages. /Bill
  2. I too had this issue addimg two additional locks (BE469ZP). I stepped away for a month and just added them in. The final steps I used to do this are the following: Reset the locks in the door Changed the programming code and user codes (This is Optional) Removed the locks and brought them right next to the EISY AFTER they were reset in the door. Set Compatibility Mode ON Set Validation OFF Secure Inclusion ON Tried to INCLUDE but FAILED two inclusion attempts, then did the following: Set Communication Speed to 30 Set Interview Timeout to 1 Minute Secure Inclusion still ON Then I did an INCLUDE and successfully added the two locks (using the 5-digit PIN) /Bill
  3. Same here...just upgraed my EISY to 6.0.0 I have over 40 hue bulns and yhen rooms and groups so a mess!
  4. I would but the "TO" seems to only give me an AM/PM option after using a FROM with the sunset as the start. Am I missing some toggle?
  5. I have a small daily program that won't run. I have the EISY (5.9.1) using a 24 Hour Claoc, alway have done so for 10 years back to an ISY and POLISY. With a program as follows: From Sunset To 10:00:00PM (Same Day) The THEN Action is always false. If I Change it to: From Sunset To 12:00:00AM (Next Day) The THEN Action works fine. I wonder if it is because of the 24 Hour clock system setting such that in the first case, the programming thinks it is actually from 1930 to 1000 same day so impossible. My thought is that the programming should switch to a 24 hour clock and not use AM/PM format. Seems like a Bug to me but have not exhaustively tested. Thoughts? /Bill
  6. Corrected today for me as well. /Bill
  7. I use a LAT/LONG custom location versus eastern time. My Sunset and Sunrise are also off by an hour, system time is correct. Reboot did not correct. EISY/5.8.4 /Bill
  8. They are all set to Yes...should they be No?
  9. I would say yes since I had code for user numbers also that I had to move to the sub node.
  10. I think you need to update the program to use the "Access Control Alarm" sub node One of my Main Lock Nodes is ZW003_1 The sub node is ZW003_306 for access control alarm Note: I also think you need parens around the "or" statements if the and applies to both. As written, I think it only allies to user 2 /Bill
  11. I have been having "Fun" with this switch. In my case, I want the Dimmer paddle to be just a virtual switch and the relay to control the line for a couple of sconces. The sconces have HUE bulbs in them. My goal was to have the ability to use the dimmer paddle to turn on and off the Hue bulbs through the ISY. As background we have a well and water softener that runs every few days from 12-4am. The sconces glow red to warn those of us that wake up to pee in the middle of the night not to flush. I don't have a 7x24 filter system so unfiltered water would come in at that time. I keep trying different programs knowing it is futile but maybe there is some way to link together a series of events to get what I want. ISY994ZW Pro (500 Series board, fw:5.3.3) Polisy running Hue Poly /Bill
  12. Kind of nice to know someone else saw this! Bill
  13. Thanks, Possible, but I do have powered devices (On/Off Power Modules Plugged in to outlets within 10' of each of the locks. Three Zooz double Outlets (Zen25) One a Honeywell UltraPro Dual Outlet I have 25 Z-Wave Devices, 7 battery powered The one lock that reported properly was near one of the Zen25s and located in an out building ironically!
  14. Running Version 5.3.3 Fairly solid Mesh by my experience but not formally tested with a Z-Wave Tool. I have four Z-Wave Plus, Schlage BE469ZP Locks, I also have a couple of Zooz Z-Wave Plus Motion Sensors and a Dome Mouser. They all seem to operate fairly reliably except for keeping their current status consistently updated in ISY. I am less concerned with the Motion and Mouser but would like to always have the proper current state of the locks reported. The locks respond to commands and report status changes when operated. However, after the 3am ISY System query, SOME, usually not all, report status UNKNOWN. I cannot find a common explanation of when one will or will not report an UNKNOWN status. This morning for example, the one furthest from the ISY reported a LOCKED status, the two Closest to ISY report UNKNOWN and the last one reports UNLOCKED but that one was used this morning already. Any thoughts? Thanks! Bill
  15. HaHa...I'm a Ham & Egger with my ISY. So I poke in here as often as I can! I have programs that use the Access Control Node to send notifications: If Jammed If Locked by Code, it includes the User Number in the Text IF Locked by Key/Manually and a two step program (Two Programs ) to report if Remotely Locked. In this case if the door was locked but not by code or by key/Manually then it was done Remotely! Also Programs for UNLOCKING, by Code, Key or Remotely. Bill
