  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
fustesj99
  1. @Javi, I got it to work from HA, I used the following as you provided; com.universaldevices.udmobile thanks again for the help...
  2. Thanks as always for the quick reply. Now, I was also trying to call the UD Mobile app from Home Assistant. What I just need is to call the app as if we do it directly from android, something like; app://com.oneclicktocontrol.udi Just to bring the app up and continue using it as normal.
  3. Hello, I'm creating an android chrome page and will like to add a link in which I can call UD Mobile from the hyperlink on the webpage. I found the android url for the old UDI app but haven't found the one in use for UD Mobile, any idea? Does the internal link call a mobile webpage? Thanks in advance... José
  4. Hi Javi, Found the issue, my network firewall was monitoring the ISY994i and apparently they applied a new FW which started to caused that behavior. Sorry for the inconvenience, and thanks for your immediate assistance as always....
  5. ISY994i with 5.34 since that version was out. No failures at all, only that issue with the UD mobile since yesterday around 4pm.
  6. Hi Javi, Thanks for the quick response. No error on any of the two options. The test remote connection succesfully passed.. I checked in my home network and outside using my cel data with the same Error 404.
  7. Hello, My connection still going Restarting Connection then Disconnected with Error 404. The connection to the portal is Online and if I manually refresh the system, the refresh works. But if I go to my favorites, I have to access one by one in order to see their actual state. The ISY was restarted and I logged out from the UD Mobile app and log back in with the same result. Any idea?
  8. fustesj99 replied to DennisC's topic in UD Mobile
    The update was ready at the Google Play now. Installed and it is back to normal.... Thanks so much....
  9. fustesj99 replied to DennisC's topic in UD Mobile
    Sure, will do now.... Thanks..
  10. fustesj99 replied to DennisC's topic in UD Mobile
    Yes, my actual version is 0.174. I did the Test Remote Connection for each one of my two systems getting the same error; Url is null. 1003
  11. fustesj99 replied to DennisC's topic in UD Mobile
    Hi, My UD mobile says connected but I can't sync. Got the following error; COULD NOT PERFORM SYNC java.lang.Error: java.lang.Error: Url is null. 1003 Is the portal still having connection issues? Thanks....
  12. fustesj99 replied to DennisC's topic in UD Mobile
  13. Thanks as always...
  14. Thanks Tazman. I was reading the 5.0.16C discussion by Chris Jahn, which explain what you just confirmed. I think will probably end up upgrading to the latest available and remove the 300 series Z-Wave board. Still looking for a new Z-Wave board....😒
  15. Thanks. Now how do you explain why I'm not seeing the Link Management menu for Insteon devices? Could it be the firmware actually installed? This is the first ISY994i or 994 that I see without that option. What could be the issue? Upgrade to a newer firmware version?
