Portal Maintenance March 18th ×
remotesanitizer
  • Posts
    6
Everything posted by remotesanitizer
  1. So, just posting an update on this, eventually I found from the log that there was an Insteon device (a sensor) that was sending multiple status changes every second or so, and that was causing everything to get overwhelmed. Once I removed that device the problems cleared up.
  2. I looked at the log and it has lots of queue full messages like this: 2022/08/07 18:46:41 System -170001 UDQ: Queue(s) Full, message ignored 2022/08/07 18:46:51 System -170001 UDQ: Queue(s) Full, message ignored 2022/08/07 18:47:02 System -170001 UDQ: Queue(s) Full, message ignored 2022/08/07 18:47:12 System -170001 UDQ: Queue(s) Full, message ignored 2022/08/07 18:47:23 System -170001 UDQ: Queue(s) Full, message ignored 2022/08/07 18:47:33 System -170001 UDQ: Queue(s) Full, message ignored 2022/08/07 16:58:29 System -7123 ID 0058 :err=0, tag='status', num=44, nest=4, o 2022/08/07 16:58:32 System -170001 [Network] Established 2022/08/07 16:59:49 System -5011 uuid:0 There are about five or six of those queue full messages each minute.
  3. Yeah, I have that set. One of the things I tried is updating to the latest version of Java, which apparently made it lose that Runtime Parameter, but I added it back (to both the 32 bit and 64 bit versions). I'm not sure if the programs are running either. And I'm not able to control any devices from https://my.isy.io/ (it shows the devices, but clicking on/off doesn't do anything). At the bottom of that page it says "error, Loading: /nodes/17 28 F9 1/cmd/DON". It just seems like pretty much nothing is working correctly.
  4. I seem to be having multiple issues with the ISY Admin Console Java UI today. It seems to be doing a never ending loop of "system busy" progress bars. If I go to the Programs tab, it gets stuck on Loading and never finishes. When I tried to query a device it gave me an error "isy994 driver not found no network connection [[DHCP] state=RENEW]". Also, when I try to control devices using the mobile app I'm getting "error 404" errors. Google Home no longer works to control devices either. Any idea what is causing all these issues? Both the firmware and UI are on version 5.3.4. Java is version 8 update 341. I tried unplugging the ISY and replugging it in.
  5. Where can I find ISY firmware upgrade info? The wiki https://wiki.universal-devices.com/index.php?title=Current_Official_Firmware_Releases link is currently broken.
  6. What firmware version do we need to be able to use it fully? Is there a firmware that isn't in beta that works with it?
  • Create New...
